System Administration Guide: Security Services
SPARC: Controlling Access to System Hardware (Task Map)
The following task map describes how to protect the PROM from unwanted access.
For Instructions
Prevent users from changing system hardware settings
Requires a password to modify PROM settings.
How to Require a Password for Hardware Access
Disable the abort sequence
Prevents users from accessing the PROM.
How to Disable a System's Abort Sequence
