System Administration Guide: Security Services
ProcedureHow to Set Up Host-Based Authentication for Solaris Secure Shell
The following procedure sets up a public key system where the client's public key is used for authentication on the server. The user must also create a public/private key pair.
In the procedure, the terms client and local host refer to the machine where a user types the ssh command. The terms server and remote host refer to the machine that the client is trying to reach.
  1. Assume the Primary Administrator role, or become superuser.
    The Primary Administrator role includes the Primary Administrator profile. To create the role and assign the role to a user, see Chapter 2, Working With the Solaris Management Console (Tasks), in System Administration Guide: Basic Administration.
  2. On the client, enable host-based authentication.
    In the client configuration file, /etc/ssh/ssh_config, type the following entry:
    HostbasedAuthentication yes
    For the syntax of the file, see the ssh_config(4) man page
  3. On the server, enable host-based authentication.
    In the server configuration file, /etc/ssh/sshd_config, type the same entry:
    For the syntax of the file, see the sshd_config(4) man page
  4. On the server, configure a file that enables the client to be recognized as a trusted host.
    For more information, see the FILES section of the sshd(1M) man page.
    • Add the client as an entry to the server's /etc/ssh/shosts.equiv file.
    • Or, you can instruct users to add an entry for the client to their ~/.shosts file on the server.
  5. On the server, ensure that the sshd daemon can access the list of trusted hosts.
    Set IgnoreRhosts to no in the /etc/ssh/sshd_config file.
    ## sshd_config
    IgnoreRhosts no
  6. Ensure that users of Solaris Secure Shell at your site have accounts on both hosts.
  7. Do one of the following to put the client's public key on the server.
    • Modify the sshd_config file on the server, then instruct your users to add the client's public host keys to their ~/.ssh/known_hosts file.
      ## sshd_config
      IgnoreUserKnownHosts no
      For user instructions, see How to Generate a Public/Private Key Pair for Use With Solaris Secure Shell.
    • Copy the client's public key to the server.
      The host keys are stored in the /etc/ssh directory. The keys are typically generated by the sshd daemon on first boot.
      1. Add the key to the /etc/ssh/ssh_known_hosts file on the server.
        On the client, type the command on one line with no backslash.
        # cat /etc/ssh/ | ssh RemoteHost \
        'cat >> /etc/ssh/ssh_known_hosts && echo "Host key copied"'
      2. When you are prompted, supply your login password.
        When the file is copied, the message “Host key copied” is displayed.
        Each line in the /etc/ssh/ssh_known_hosts file consists of fields that are separated by spaces:
        hostnames algorithm-name publickey comment
      3. Edit the /etc/ssh/ssh_known_hosts file and add RemoteHost as the first field in the copied entry.
        ## /etc/ssh/ssh_known_hosts File
        RemoteHost <copied entry>
Example 19–1 Setting Up Host-based Authentication
In the following example, each host is configured as a server and as a client. A user on either host can initiate an ssh connection to the other host. The following configuration makes each host a server and a client:
