System Administration Guide: Security Services
Configuring Solaris Secure Shell
By default, host-based authentication and the use of both protocols are not enabled in Solaris Secure Shell. Changing these defaults requires administrative intervention. Also, for port forwarding to work requires administrative intervention.
ProcedureHow to Set Up Host-Based Authentication for Solaris Secure Shell
The following procedure sets up a public key system where the client's public key is used for authentication on the server. The user must also create a public/private key pair.
In the procedure, the terms client and local host refer to the machine where a user types the ssh command. The terms server and remote host refer to the machine that the client is trying to reach.
  1. Assume the Primary Administrator role, or become superuser.
    The Primary Administrator role includes the Primary Administrator profile. To create the role and assign the role to a user, see Chapter 2, Working With the Solaris Management Console (Tasks), in System Administration Guide: Basic Administration.
  2. On the client, enable host-based authentication.
    In the client configuration file, /etc/ssh/ssh_config, type the following entry:
    HostbasedAuthentication yes
    For the syntax of the file, see the ssh_config(4) man page
  3. On the server, enable host-based authentication.
    In the server configuration file, /etc/ssh/sshd_config, type the same entry:
    For the syntax of the file, see the sshd_config(4) man page
  4. On the server, configure a file that enables the client to be recognized as a trusted host.
    For more information, see the FILES section of the sshd(1M) man page.
    • Add the client as an entry to the server's /etc/ssh/shosts.equiv file.
      client-host
    • Or, you can instruct users to add an entry for the client to their ~/.shosts file on the server.
      client-host
  5. On the server, ensure that the sshd daemon can access the list of trusted hosts.
    Set IgnoreRhosts to no in the /etc/ssh/sshd_config file.
    ## sshd_config
    IgnoreRhosts no
  6. Ensure that users of Solaris Secure Shell at your site have accounts on both hosts.
  7. Do one of the following to put the client's public key on the server.
    • Modify the sshd_config file on the server, then instruct your users to add the client's public host keys to their ~/.ssh/known_hosts file.
      ## sshd_config
      IgnoreUserKnownHosts no
      For user instructions, see How to Generate a Public/Private Key Pair for Use With Solaris Secure Shell.
    • Copy the client's public key to the server.
      The host keys are stored in the /etc/ssh directory. The keys are typically generated by the sshd daemon on first boot.
      1. Add the key to the /etc/ssh/ssh_known_hosts file on the server.
        On the client, type the command on one line with no backslash.
        # cat /etc/ssh/ssh_host_dsa_key.pub | ssh RemoteHost \
        'cat >> /etc/ssh/ssh_known_hosts && echo "Host key copied"'
      2. When you are prompted, supply your login password.
        When the file is copied, the message “Host key copied” is displayed.
        Each line in the /etc/ssh/ssh_known_hosts file consists of fields that are separated by spaces:
        hostnames algorithm-name publickey comment
      3. Edit the /etc/ssh/ssh_known_hosts file and add RemoteHost as the first field in the copied entry.
        ## /etc/ssh/ssh_known_hosts File
        RemoteHost <copied entry>
Example 19–1 Setting Up Host-based Authentication
In the following example, each host is configured as a server and as a client. A user on either host can initiate an ssh connection to the other host. The following configuration makes each host a server and a client:
ProcedureHow to Enable Solaris Secure Shell v1
This procedure is useful when a host interoperates with hosts that run v1 and v2.
  2. Configure the host to use both Solaris Secure Shell protocols.
    Edit the /etc/ssh/sshd_config file.
    # Protocol 2
    Protocol 2,1
  3. Provide a separate file for the host key for v1.
    Add a HostKey entry to the /etc/ssh/sshd_config file.
    HostKey /etc/ssh/ssh_host_rsa_key
    HostKey /etc/ssh/ssh_host_dsa_key
    HostKey /etc/ssh/ssh_host_rsa1_key
  4. Generate a host key for v1.
    # ssh-keygen -t rsa1 -f /etc/ssh/ssh_host_rsa1_key -N ''
    -t rsa1
    Indicates the RSA algorithm for v1.
    -f
    Indicates the file that holds the host key.
    -N ''
    Indicates that no passphrase is required.
  5. Restart the sshd daemon.
    # svcadm restart network/ssh:default
    You can also reboot the system.
ProcedureHow to Configure Port Forwarding in Solaris Secure Shell
Port forwarding enables a local port be forwarded to a remote host. Effectively, a socket is allocated to listen to the port on the local side. Similarly, a port can be specified on the remote side.
Note –
Solaris Secure Shell port forwarding must use TCP connections. Solaris Secure Shell does not support UDP connections for port forwarding.
  2. Configure a Solaris Secure Shell setting on the remote server to allow port forwarding.
    Change the value of AllowTcpForwarding to yes in the /etc/ssh/sshd_config file.
    # Port forwarding
    AllowTcpForwarding yes
  3. Restart the Solaris Secure Shell service.
    remoteHost# svcadm restart network/ssh:default
    For information on managing persistent services, see Chapter 18, Managing Services (Overview), in System Administration Guide: Basic Administration and the svcadm(1M) man page.
  4. Verify that port forwarding can be used.
    remoteHost# /usr/bin/pgrep -lf sshd
     1296 ssh -L 2001:remoteHost:23 remoteHost
