System Administration Guide: Security Services
SEAM Administration Tool Error Messages
Unable to view the list of principals or policies; use the Name field.
Cause:
The admin principal that you logged in with does not have the list privilege (l) in the Kerberos ACL file (kadm5.acl). So, you cannot view the principal list or policy list.
Solution:
You must type the principal and policy names in the Name field to work on them, or you need to log in with a principal that has the appropriate privileges.
JNI: Java array creation failed
JNI: Java class lookup failed
JNI: Java field lookup failed
JNI: Java method lookup failed
JNI: Java object lookup failed
JNI: Java object field lookup failed
JNI: Java string access failed
JNI: Java string creation failed
Cause:
A serious problem exists with the Java Native Interface that is used by the SEAM Administration Tool (gkadmin).
Solution:
Exit gkadmin and restart it. If the problem persists, please report a bug.
