Writing Device Drivers
Creating Faults
The th_define utility provides an interface to the bofi device driver for defining errdefs. An errdef corresponds to a specification for how to corrupt a device driver's accesses to its hardware. The th_define command-line arguments determine the precise nature of the fault to be injected. If the supplied arguments define a consistent errdef, the th_define process stores the errdef with the bofi driver. The process suspends itself until the criteria given by the errdef becomes satisfied. In practice, the suspension ends when the access counts go to zero (0).
