Writing Device Drivers
Programmed I/O Functions
The programmed I/O functions are:
ddi_dev_nregs()
Return the number of register sets a device has
ddi_dev_regsize()
Return the size of a device's register
ddi_regs_map_setup()
Set up a mapping for a register address space
ddi_regs_map_free()
Free a previously mapped register address space
ddi_device_copy()
Copy data from one device register to another device register
ddi_device_zero()
Zero fill the device
ddi_check_acc_handle()
Check data access handle
ddi_get8()
Read 8-bit data from mapped memory, device register, or DMA memory
ddi_get16()
Read 16-bit data from mapped memory, device register, or DMA memory
ddi_get32()
Read 32-bit data from mapped memory, device register, or DMA memory
ddi_get64()
Read 64-bit data from mapped memory, device register, or DMA memory
ddi_put8()
Write 8-bit data to mapped memory, device register, or DMA memory
ddi_put16()
Write 16-bit data to mapped memory, device register, or DMA memory
ddi_put32()
Write 32-bit data to mapped memory, device register, or DMA memory
ddi_put64()
Write 64-bit data to mapped memory, device register, or DMA memory
ddi_rep_get8()
Read multiple 8-bit data from mapped memory, device register, or DMA memory
ddi_rep_get16()
Read multiple 16-bit data from mapped memory, device register, or DMA memory
ddi_rep_get32()
Read multiple 32-bit data from mapped memory, device register, or DMA memory
ddi_rep_get64()
Read multiple 64-bit data from mapped memory, device register, or DMA memory
ddi_rep_put8()
Write multiple 8-bit data to mapped memory, device register, or DMA memory
ddi_rep_put16()
Write multiple 16-bit data to mapped memory, device register, or DMA memory
ddi_rep_put32()
Write multiple 32-bit data to mapped memory, device register, or DMA memory
ddi_rep_put64()
Write multiple 64-bit data to mapped memory, device register, or DMA memory
ddi_peek8()
Cautiously read an 8-bit value from a location
ddi_peek16()
Cautiously read a 16-bit value from a location
ddi_peek32()
Cautiously read a 32-bit value from a location
ddi_peek64()
Cautiously read a 64-bit value from a location
ddi_poke8()
Cautiously write an 8-bit value to a location
ddi_poke16()
Cautiously write a 16-bit value to a location
ddi_poke32()
Cautiously write a 32-bit value to a location
ddi_poke64()
Cautiously write a 64-bit value to a location
The general programmed I/O functions listed above can always be used rather than the mem, io, and pci_config functions that follow. However, the following functions can be used as alternatives in cases where the type of access is known at compile time.
ddi_io_get8()
Read 8-bit data from a mapped device register in I/O space
ddi_io_get16()
Read 16-bit data from a mapped device register in I/O space
ddi_io_get32()
Read 32-bit data from a mapped device register in I/O space
ddi_io_put8()
Write 8-bit data to a mapped device register in I/O space
ddi_io_put16()
Write 16-bit data to a mapped device register in I/O space
ddi_io_put32()
Write 32-bit data to a mapped device register in I/O space
ddi_io_rep_get8()
Read multiple 8-bit data from a mapped device register in I/O space
ddi_io_rep_get16()
Read multiple 16-bit data from a mapped device register in I/O space
ddi_io_rep_get32()
Read multiple 32-bit data from a mapped device register in I/O space
ddi_io_rep_put8()
Write multiple 8-bit data to a mapped device register in I/O space
ddi_io_rep_put16()
Write multiple 16-bit data to a mapped device register in I/O space
ddi_io_rep_put32()
Write multiple 32-bit data to a mapped device register in I/O space
ddi_mem_get8()
Read 8-bit data from a mapped device in memory space or DMA memory
ddi_mem_get16()
Read 16-bit data from a mapped device in memory space or DMA memory
ddi_mem_get32()
Read 32-bit data from a mapped device in memory space or DMA memory
ddi_mem_get64()
Read 64-bit data from a mapped device in memory space or DMA memory
ddi_mem_put8()
Write 8-bit data to a mapped device in memory space or DMA memory
ddi_mem_put16()
Write 16-bit data to a mapped device in memory space or DMA memory
ddi_mem_put32()
Write 32-bit data to a mapped device in memory space or DMA memory
ddi_mem_put64()
Write 64-bit data to a mapped device in memory space or DMA memory
ddi_mem_rep_get8()
Read multiple 8-bit data from a mapped device in memory space or DMA memory
ddi_mem_rep_get16()
Read multiple 16-bit data from a mapped device in memory space or DMA memory
ddi_mem_rep_get32()
Read multiple 32-bit data from a mapped device in memory space or DMA memory
ddi_mem_rep_get64()
Read multiple 64-bit data from a mapped device in memory space or DMA memory
ddi_mem_rep_put8()
Write multiple 8-bit data to a mapped device in memory space or DMA memory
ddi_mem_rep_put16()
Write multiple 16-bit data to a mapped device in memory space or DMA memory
ddi_mem_rep_put32()
Write multiple 32-bit data to a mapped device in memory space or DMA memory
ddi_mem_rep_put64()
Write multiple 64-bit data to a mapped device in memory space or DMA memory
pci_config_setup()
Set up access to PCI Local Bus Configuration space
pci_config_teardown()
Tear down access to PCI Local Bus Configuration space
pci_config_get8()
Read 8-bit data from the PCI Local Bus Configuration space
pci_config_get16()
Read 16-bit data from the PCI Local Bus Configuration space
pci_config_get32()
Read 32-bit data from the PCI Local Bus Configuration space
pci_config_get64()
Read 64-bit data from the PCI Local Bus Configuration space
pci_config_put8()
Write 8-bit data to the PCI Local Bus Configuration space
pci_config_put16()
Write 16-bit data to the PCI Local Bus Configuration space
pci_config_put32()
Write 32-bit data to the PCI Local Bus Configuration space
pci_config_put64()
Write 64-bit data to the PCI Local Bus Configuration space
Table B–4 Deprecated Programmed I/O Functions
Deprecated Function
Replacement
ddi_getb()
ddi_get8()
ddi_getl()
ddi_get32()
ddi_getll()
ddi_get64()
ddi_getw()
ddi_get16()
ddi_io_getb()
ddi_io_get8()
ddi_io_getl()
ddi_io_get32()
ddi_io_getw()
ddi_io_get16()
ddi_io_putb()
ddi_io_put8()
ddi_io_putl()
ddi_io_put32()
ddi_io_putw()
ddi_io_put16()
ddi_io_rep_getb()
ddi_io_rep_get8()
ddi_io_rep_getl()
ddi_io_rep_get32()
ddi_io_rep_getw()
ddi_io_rep_get16()
ddi_io_rep_putb()
ddi_io_rep_put8()
ddi_io_rep_putl()
ddi_io_rep_put32()
ddi_io_rep_putw()
ddi_io_rep_put16()
ddi_map_regs()
ddi_mem_getb()
ddi_mem_get8()
ddi_mem_getl()
ddi_mem_get32()
ddi_mem_getll()
ddi_mem_get64()
ddi_mem_getw()
ddi_mem_get16()
ddi_mem_putb()
ddi_mem_put8()
ddi_mem_putl()
ddi_mem_put32()
ddi_mem_putll()
ddi_mem_put64()
ddi_mem_putw()
ddi_mem_put16()
ddi_mem_rep_getb()
ddi_mem_rep_get8()
ddi_mem_rep_getl()
ddi_mem_rep_get32()
ddi_mem_rep_getll()
ddi_mem_rep_get64()
ddi_mem_rep_getw()
ddi_mem_rep_get16()
ddi_mem_rep_putb()
ddi_mem_rep_put8()
ddi_mem_rep_putl()
ddi_mem_rep_put32()
ddi_mem_rep_putll()
ddi_mem_rep_put64()
ddi_mem_rep_putw()
ddi_mem_rep_put16()
ddi_peekc()
ddi_peek8()
ddi_peekd()
ddi_peek64()
ddi_peekl()
ddi_peek32()
ddi_peeks()
ddi_peek16()
ddi_pokec()
ddi_poke8()
ddi_poked()
ddi_poke64()
ddi_pokel()
ddi_poke32()
ddi_pokes()
ddi_poke16()
ddi_putb()
ddi_put8()
ddi_putl()
ddi_put32()
ddi_putll()
ddi_put64()
ddi_putw()
ddi_put16()
ddi_rep_getb()
ddi_rep_get8()
ddi_rep_getl()
ddi_rep_get32()
ddi_rep_getll()
ddi_rep_get64()
ddi_rep_getw()
ddi_rep_get16()
ddi_rep_putb()
ddi_rep_put8()
ddi_rep_putl()
ddi_rep_put32()
ddi_rep_putll()
ddi_rep_put64()
ddi_rep_putw()
ddi_rep_put16()
ddi_unmap_regs()
ddi_regs_map_free()
inb()
ddi_io_get8()
inl()
ddi_io_get32()
inw()
ddi_io_get16()
outb()
ddi_io_put8()
outl()
ddi_io_put32()
outw()
ddi_io_put16()
pci_config_getb()
pci_config_get8()
pci_config_getl()
pci_config_get32()
pci_config_getll()
pci_config_get64()
pci_config_getw()
pci_config_get16()
pci_config_putb()
pci_config_put8()
pci_config_putl()
pci_config_put32()
pci_config_putll()
pci_config_put64()
pci_config_putw()
pci_config_put16()
repinsb()
ddi_io_rep_get8()
repinsd()
ddi_io_rep_get32()
repinsw()
ddi_io_rep_get16()
repoutsb()
ddi_io_rep_put8()
repoutsd()
ddi_io_rep_put32()
repoutsw()
ddi_io_rep_put16()
