Writing Device Drivers
GLDv2 Network Statistics
Solaris network drivers must implement statistics variables. GLDv2 tallies some network statistics, but other statistics must be counted by each GLDv2-based driver. GLDv2 provides support for GLDv2-based drivers to report a standard set of network driver statistics. Statistics are reported by GLDv2 using the kstat(7D) and kstat(9S) mechanisms. The DL_GET_STATISTICS_REQ DLPI command can also be used to retrieve the current statistics counters. All statistics are maintained as unsigned. The statistics are 32 bits unless otherwise noted.
GLDv2 maintains and reports the following statistics.
rbytes64
Total bytes successfully received on the interface. Stores 64-bit statistics.
rbytes
obytes64
Total bytes that have requested transmission on the interface. Stores 64-bit statistics.
obytes
ipackets64
Total packets successfully received on the interface. Stores 64-bit statistics.
ipackets
opackets64
Total packets that have requested transmission on the interface. Stores 64-bit statistics.
opackets
multircv
Multicast packets successfully received, including group and functional addresses (long).
multixmt
Multicast packets requested to be transmitted, including group and functional addresses (long).
brdcstrcv
Broadcast packets successfully received (long).
brdcstxmt
Broadcast packets that have requested transmission (long).
unknowns
Valid received packets not accepted by any stream (long).
noxmtbuf
Packets discarded on output because transmit buffer was busy, or no buffer could be allocated for transmit (long).
blocked
Number of times a received packet could not be put up a stream because the queue was flow-controlled (long).
xmtretry
Times transmit was retried after having been delayed due to lack of resources (long).
promisc
Current “promiscuous” state of the interface (string).
The device-dependent driver tracks the following statistics in a private per-instance structure. To report statistics, GLDv2 calls the driver's gldm_get_stats() entry point. gldm_get_stats() then updates device-specific statistics in the gld_stats(9S) structure. See the gldm_get_stats(9E) man page for more information. GLDv2 then reports the updated statistics using the named statistics variables that are shown below.
ifspeed
Current estimated bandwidth of the interface in bits per second. Stores 64-bit statistics.
media
Current media type in use by the device (string).
intr
Number of times that the interrupt handler was called, causing an interrupt (long).
norcvbuf
Number of times a valid incoming packet was known to have been discarded because no buffer could be allocated for receive (long).
ierrors
Total number of packets that were received but could not be processed due to errors (long).
oerrors
Total packets that were not successfully transmitted because of errors (long).
missed
Packets known to have been dropped by the hardware on receive (long).
uflo
Times FIFO underflowed on transmit (long).
oflo
Times receiver overflowed during receive (long).
The following group of statistics applies to networks of type DL_ETHER. These statistics are maintained by device-specific drivers of that type, as shown previously.
align_errors
Packets that were received with framing errors, that is, the packets did not contain an integral number of octets (long).
fcs_errors
Packets received with CRC errors (long).
duplex
Current duplex mode of the interface (string).
carrier_errors
Number of times carrier was lost or never detected on a transmission attempt (long).
collisions
Ethernet collisions during transmit (long).
ex_collisions
Frames where excess collisions occurred on transmit, causing transmit failure (long).
tx_late_collisions
Number of times a transmit collision occurred late, that is, after 512 bit times (long).
defer_xmts
Packets without collisions where first transmit attempt was delayed because the medium was busy (long).
first_collisions
Packets successfully transmitted with exactly one collision.
multi_collisions
Packets successfully transmitted with multiple collisions.
sqe_errors
Number of times that SQE test error was reported.
macxmt_errors
Packets encountering transmit MAC failures, except carrier and collision failures.
macrcv_errors
Packets received with MAC errors, except align_errors, fcs_errors, and toolong_errors.
toolong_errors
Packets received larger than the maximum allowed length.
runt_errors
Packets received smaller than the minimum allowed length (long).
The following group of statistics applies to networks of type DL_TPR. These statistics are maintained by device-specific drivers of that type, as shown above.
line_errors
Packets received with non-data bits or FCS errors.
burst_errors
Number of times an absence of transitions for five half-bit timers was detected.
signal_losses
Number of times loss of signal condition on the ring was detected.
ace_errors
Number of times that an AMP or SMP frame, in which A is equal to C is equal to 0, is followed by another SMP frame without an intervening AMP frame.
internal_errors
Number of times the station recognized an internal error.
lost_frame_errors
Number of times the TRR timer expired during transmit.
frame_copied_errors
Number of times a frame addressed to this station was received with the FS field `A' bit set to 1.
token_errors
Number of times the station acting as the active monitor recognized an error condition that needed a token transmitted.
freq_errors
Number of times the frequency of the incoming signal differed from the expected frequency.
The following group of statistics applies to networks of type DL_FDDI. These statistics are maintained by device-specific drivers of that type, as shown above.
mac_errors
Frames detected in error by this MAC that had not been detected in error by another MAC.
mac_lost_errors
Frames received with format errors such that the frame was stripped.
mac_tokens
Number of tokens that were received, that is, the total of non-restricted and restricted tokens.
mac_tvx_expired
Number of times that TVX has expired.
mac_late
Number of TRT expirations since either this MAC was reset or a token was received.
mac_ring_ops
Number of times the ring has entered the “Ring Operational” state from the “Ring Not Operational” state.
