Writing Device Drivers
power() Entry Point
The power management framework uses the power(9E) entry point.
power() uses the following syntax:
int power(dev_info_t *dip, int component, int level);
When a component's power level needs to be changed, the system calls the power(9E) entry point. The action taken by this entry point is device driver-specific. In the example of the SCSI target disk driver mentioned previously, setting the power level to 0 results in sending a SCSI command to spin down the disk, while setting the power level to the full power level results in sending a SCSI command to spin up the disk.
If a power transition can cause the device to lose state, the driver must save any necessary state in memory for later restoration. If a power transition requires the saved state to be restored before the device can be used again, then the driver must restore that state. The framework makes no assumptions about what power transactions cause the loss of state or require the restoration of state for automatically power-managed devices. The following example shows a sample power() routine.
Example 12–4 Using the power() Routine for a Single-Component Device
int
xxpower(dev_info_t *dip, int component, int level)
    struct xxstate *xsp;
    int instance;
    instance = ddi_get_instance(dip);
    xsp = ddi_get_soft_state(statep, instance);
    * Make sure the request is valid
    if (!xx_valid_power_level(component, level))
        return (DDI_FAILURE);
    mutex_enter(&xsp->mu);
    * If the device is busy, don't lower its power level
    if (xsp->xx_busy[component] &&
        xsp->xx_power_level[component] > level) {
        mutex_exit(&xsp->mu);
    if (xsp->xx_power_level[component] != level) {
        * device- and component-specific setting of power level
        * goes here
        xsp->xx_power_level[component] = level;
    return (DDI_SUCCESS);
The following example is a power() routine for a device with two components, where component 0 must be on when component 1 is on.
Example 12–5 power(9E) Routine for Multiple-Component Device
int
    int instance;
    * This code implements inter-component dependencies:
    * If we are bringing up component 1 and component 0
    * is off, we must bring component 0 up first, and if
    * we are asked to shut down component 0 while component
    * 1 is up we must refuse
    if (component == 1 && level > 0 && xsp->xx_power_level[0] == 0) {
        xsp->xx_busy[0]++;
        if (pm_busy_component(dip, 0) != DDI_SUCCESS) {
            * This can only happen if the args to
            * pm_busy_component()
            * are wrong, or pm-components property was not
            * exported by the driver.
            xsp->xx_busy[0]--;
            cmn_err(CE_WARN, "xxpower pm_busy_component()
                failed");
        if (pm_raise_power(dip, 0, XX_FULL_POWER_0) != DDI_SUCCESS)
    if (component == 0 && level == 0 && xsp->xx_power_level[1] != 0) {
        * goes here
