In addition to incorporating SCSA HBA entry points, structures, and functions into a driver, a developer must deal with driver dependency and configuration issues. These issues involve configuration properties, dependency declarations, state structure and per-command structure, entry points for module initialization, and autoconfiguration entry points.
HBA drivers must include the following header files:
#include <sys/scsi/scsi.h> #include <sys/ddi.h> #include <sys/sunddi.h>
To inform the system that the module depends on SCSA routines, the driver binary must be generated with the following command. See SCSA HBA Interfaces for more information on SCSA routines.
% ld -r xx.o -o xx -N "misc/scsi" |
The code samples are derived from a simplified isp driver for the QLogic Intelligent SCSI Peripheral device. The isp driver supports WIDE SCSI, with up to 15 target devices and 8 logical units (LUNs) per target.
An HBA driver usually needs to define a structure to maintain state for each command submitted by a target driver. The layout of this per-command structure is entirely up to the device driver writer. The layout needs to reflect the capabilities and features of the hardware and the software algorithms that are used in the driver.
The following structure is an example of a per-command structure. The remaining code fragments of this chapter use this structure to illustrate the HBA interfaces.
struct isp_cmd { struct isp_request cmd_isp_request; struct isp_response cmd_isp_response; struct scsi_pkt *cmd_pkt; struct isp_cmd *cmd_forw; uint32_t cmd_dmacount; ddi_dma_handle_t cmd_dmahandle; uint_t cmd_cookie; uint_t cmd_ncookies; uint_t cmd_cookiecnt; uint_t cmd_nwin; uint_t cmd_curwin; off_t cmd_dma_offset; uint_t cmd_dma_len; ddi_dma_cookie_t cmd_dmacookies[ISP_NDATASEGS]; u_int cmd_flags; u_short cmd_slot; u_int cmd_cdblen; u_int cmd_scblen; };
This section describes the entry points for operations that are performed by SCSI HBA drivers.
The following code for a SCSI HBA driver illustrates a representative dev_ops(9S) structure. The driver must initialize the devo_bus_ops field in this structure to NULL. A SCSI HBA driver can provide leaf driver interfaces for special purposes, in which case the devo_cb_ops field might point to a cb_ops(9S) structure. In this example, no leaf driver interfaces are exported, so the devo_cb_ops field is initialized to NULL.
The _init(9E) function initializes a loadable module. _init() is called before any other routine in the loadable module.
In a SCSI HBA, the _init() function must call scsi_hba_init(9F) to inform the framework of the existence of the HBA driver before calling mod_install(9F). If scsi_hba__init() returns a nonzero value,_init() should return this value. Otherwise, _init() must return the value returned by mod_install(9F).
The driver should initialize any required global state before calling mod_install(9F).
If mod_install() fails, the _init() function must free any global resources allocated. _init() must call scsi_hba_fini(9F) before returning.
The following example uses a global mutex to show how to allocate data that is global to all instances of a driver. The code declares global mutex and soft-state structure information. The global mutex and soft state are initialized during _init().
The _fini(9E) function is called when the system is about to try to unload the SCSI HBA driver. The _fini() function must call mod_remove(9F) to determine whether the driver can be unloaded. If mod_remove() returns 0, the module can be unloaded. The HBA driver must deallocate any global resources allocated in _init(9E). The HBA driver must also call scsi_hba_fini(9F).
_fini() must return the value returned by mod_remove().
The HBA driver must not free any resources or call scsi_hba_fini(9F) unless mod_remove(9F) returns 0.
Example 18–1 shows module initialization for SCSI HBA.
static struct dev_ops isp_dev_ops = { DEVO_REV, /* devo_rev */ 0, /* refcnt */ isp_getinfo, /* getinfo */ nulldev, /* probe */ isp_attach, /* attach */ isp_detach, /* detach */ nodev, /* reset */ NULL, /* driver operations */ NULL, /* bus operations */ isp_power, /* power management */ }; /* * Local static data */ static kmutex_t isp_global_mutex; static void *isp_state; int _init(void) { int err; if ((err = ddi_soft_state_init(&isp_state, sizeof (struct isp), 0)) != 0) { return (err); } if ((err = scsi_hba_init(&modlinkage)) == 0) { mutex_init(&isp_global_mutex, "isp global mutex", MUTEX_DRIVER, NULL); if ((err = mod_install(&modlinkage)) != 0) { mutex_destroy(&isp_global_mutex); scsi_hba_fini(&modlinkage); ddi_soft_state_fini(&isp_state); } } return (err); } int _fini(void) { int err; if ((err = mod_remove(&modlinkage)) == 0) { mutex_destroy(&isp_global_mutex); scsi_hba_fini(&modlinkage); ddi_soft_state_fini(&isp_state); } return (err); }
Associated with each device driver is a dev_ops(9S) structure, which enables the kernel to locate the autoconfiguration entry points of the driver. A complete description of these autoconfiguration routines is given in Chapter 6, Driver Autoconfiguration. This section describes only those entry points associated with operations performed by SCSI HBA drivers. These entry points include attach(9E) and detach(9E).
The attach(9E) entry point for a SCSI HBA driver performs several tasks when configuring and attaching an instance of the driver for the device. For a typical driver of real devices, the following operating system and hardware concerns must be addressed:
Soft-state structure
DMA
Transport structure
Attaching an HBA driver
Register mapping
Interrupt specification
Interrupt handling
Create power manageable components
Report attachment status
When allocating the per-device-instance soft-state structure, a driver must clean up carefully if an error occurs.
The HBA driver must describe the attributes of its DMA engine by properly initializing the ddi_dma_attr_t structure.
static ddi_dma_attr_t isp_dma_attr = { DMA_ATTR_V0, /* ddi_dma_attr version */ 0, /* low address */ 0xffffffff, /* high address */ 0x00ffffff, /* counter upper bound */ 1, /* alignment requirements */ 0x3f, /* burst sizes */ 1, /* minimum DMA access */ 0xffffffff, /* maximum DMA access */ (1<<24)-1, /* segment boundary restrictions */ 1, /* scatter-gather list length */ 512, /* device granularity */ 0 /* DMA flags */ };
The driver, if providing DMA, should also check that its hardware is installed in a DMA-capable slot:
if (ddi_slaveonly(dip) == DDI_SUCCESS) { return (DDI_FAILURE); }
The driver should further allocate and initialize a transport structure for this instance. The tran_hba_private field is set to point to this instance's soft-state structure. The tran_tgt_probe field can be set to NULL to achieve the default behavior, if no special probe customization is needed.
tran = scsi_hba_tran_alloc(dip, SCSI_HBA_CANSLEEP); isp->isp_tran = tran; isp->isp_dip = dip; tran->tran_hba_private = isp; tran->tran_tgt_private = NULL; tran->tran_tgt_init = isp_tran_tgt_init; tran->tran_tgt_probe = scsi_hba_probe; tran->tran_tgt_free = (void (*)())NULL; tran->tran_start = isp_scsi_start; tran->tran_abort = isp_scsi_abort; tran->tran_reset = isp_scsi_reset; tran->tran_getcap = isp_scsi_getcap; tran->tran_setcap = isp_scsi_setcap; tran->tran_init_pkt = isp_scsi_init_pkt; tran->tran_destroy_pkt = isp_scsi_destroy_pkt; tran->tran_dmafree = isp_scsi_dmafree; tran->tran_sync_pkt = isp_scsi_sync_pkt; tran->tran_reset_notify = isp_scsi_reset_notify; tran->tran_bus_quiesce = isp_tran_bus_quiesce tran->tran_bus_unquiesce = isp_tran_bus_unquiesce tran->tran_bus_reset = isp_tran_bus_reset tran->tran_interconnect_type = isp_tran_interconnect_type
The driver should attach this instance of the device, and perform error cleanup if necessary.
i = scsi_hba_attach_setup(dip, &isp_dma_attr, tran, 0); if (i != DDI_SUCCESS) { /* do error recovery */ return (DDI_FAILURE); }
The driver should map in its device's registers. The driver need to specify the following items:
Register set index
Data access characteristics of the device
Size of the register to be mapped
ddi_device_acc_attr_t dev_attributes; dev_attributes.devacc_attr_version = DDI_DEVICE_ATTR_V0; dev_attributes.devacc_attr_dataorder = DDI_STRICTORDER_ACC; dev_attributes.devacc_attr_endian_flags = DDI_STRUCTURE_LE_ACC; if (ddi_regs_map_setup(dip, 0, (caddr_t *)&isp->isp_reg, 0, sizeof (struct ispregs), &dev_attributes, &isp->isp_acc_handle) != DDI_SUCCESS) { /* do error recovery */ return (DDI_FAILURE); }
The driver must first obtain the iblock cookie to initialize any mutexes that are used in the driver handler. Only after those mutexes have been initialized can the interrupt handler be added.
i = ddi_get_iblock_cookie(dip, 0, &isp->iblock_cookie}; if (i != DDI_SUCCESS) { /* do error recovery */ return (DDI_FAILURE); } mutex_init(&isp->mutex, "isp_mutex", MUTEX_DRIVER, (void *)isp->iblock_cookie); i = ddi_add_intr(dip, 0, &isp->iblock_cookie, 0, isp_intr, (caddr_t)isp); if (i != DDI_SUCCESS) { /* do error recovery */ return (DDI_FAILURE); }
If a high-level handler is required, the driver should be coded to provide such a handler. Otherwise, the driver must be able to fail the attach. See Handling High-Level Interrupts for a description of high-level interrupt handling.
With power management, if the host bus adapter only needs to power down when all target adapters are at power level 0, the HBA driver only needs to provide a power(9E) entry point. Refer to Chapter 12, Power Management. The HBA driver also needs to create a pm-components(9P) property that describes the components that the device implements.
Nothing more is necessary, since the components will default to idle, and the power management framework's default dependency processing will ensure that the host bus adapter will be powered up whenever an target adapter is powered up. Provided that automatic power management is enabled automatically, the processing will also power down the host bus adapter when all target adapters are powered down ().
Finally, the driver should report that this instance of the device is attached and return success.
ddi_report_dev(dip); return (DDI_SUCCESS);
The driver should perform standard detach operations, including calling scsi_hba_detach(9F).
