Writing Device Drivers
Adding an Interrupt Handler
The driver must first obtain the iblock cookie to initialize any mutexes that are used in the driver handler. Only after those mutexes have been initialized can the interrupt handler be added.
i = ddi_get_iblock_cookie(dip, 0, &isp->iblock_cookie};
if (i != DDI_SUCCESS) {
    /* do error recovery */
    return (DDI_FAILURE);
mutex_init(&isp->mutex, "isp_mutex", MUTEX_DRIVER,
(void *)isp->iblock_cookie);
i = ddi_add_intr(dip, 0, &isp->iblock_cookie,
0, isp_intr, (caddr_t)isp);
If a high-level handler is required, the driver should be coded to provide such a handler. Otherwise, the driver must be able to fail the attach. See Handling High-Level Interrupts for a description of high-level interrupt handling.
