Writing Device Drivers
Command Transport
An HBA driver goes through the following steps as part of command transport:
  1. Accept a command from the target driver.
  2. Issue the command to the device hardware.
  3. Service any interrupts that occur.
  4. Manage time outs.
tran_start() Entry Point
The tran_start(9E) entry point for a SCSI HBA driver is called to transport a SCSI command to the addressed target. The SCSI command is described entirely within the scsi_pkt(9S) structure, which the target driver allocated through the HBA driver's tran_init_pkt(9E) entry point. If the command involves a data transfer, DMA resources must also have been allocated for the scsi_pkt(9S) structure.
The tran_start() entry point is called when a target driver calls scsi_transport(9F).
tran_start() should perform basic error checking along with any initialization that is required by the command. The FLAG_NOINTR flag in the pkt_flags field of the scsi_pkt(9S) structure can affect the behavior of tran_start(). If FLAG_NOINTR is not set, tran_start() must queue the command for execution on the hardware and return immediately. Upon completion of the command, the HBA driver should call the pkt completion routine.
If the FLAG_NOINTR is set, then the HBA driver should not call the pkt completion routine.
The following example demonstrates how to handle the tran_start(9E) entry point. The ISP hardware provides a queue per-target device. For devices that can manage only one active outstanding command, the driver is typically required to manage a per-target queue. The driver then starts up a new command upon completion of the current command in a round-robin fashion.
Example 18–8 HBA Driver tran_start(9E) Entry Point
static int
isp_scsi_start(
    struct scsi_address    *ap,
    struct scsi_pkt        *pkt)
    struct isp_cmd         *sp;
    struct isp             *isp;
    struct isp_request     *req;
    u_long                 cur_lbolt;
    int                    xfercount;
    int                    rval = TRAN_ACCEPT;
    int                    i;
    sp = (struct isp_cmd *)pkt->pkt_ha_private;
    isp = (struct isp *)ap->a_hba_tran->tran_hba_private;
    sp->cmd_flags = (sp->cmd_flags & ~CFLAG_TRANFLAG) |
                CFLAG_IN_TRANSPORT;
    pkt->pkt_reason = CMD_CMPLT;
    * set up request in cmd_isp_request area so it is ready to
    * go once we have the request mutex
    req = &sp->cmd_isp_request;
    req->req_header.cq_entry_type = CQ_TYPE_REQUEST;
    req->req_header.cq_entry_count = 1;
    req->req_header.cq_flags        = 0;
    req->req_header.cq_seqno = 0;
    req->req_reserved = 0;
    req->req_token = (opaque_t)sp;
    req->req_target = TGT(sp);
    req->req_lun_trn = LUN(sp);
    req->req_time = pkt->pkt_time;
    ISP_SET_PKT_FLAGS(pkt->pkt_flags, req->req_flags);
    * Set up data segments for dma transfers.
    if (sp->cmd_flags & CFLAG_DMAVALID) {
        if (sp->cmd_flags & CFLAG_CMDIOPB) {
            (void) ddi_dma_sync(sp->cmd_dmahandle,
            sp->cmd_dma_offset, sp->cmd_dma_len,
            DDI_DMA_SYNC_FORDEV);
        ASSERT(sp->cmd_cookiecnt > 0 &&
            sp->cmd_cookiecnt <= ISP_NDATASEGS);
        xfercount = 0;
        req->req_seg_count = sp->cmd_cookiecnt;
        for (i = 0; i < sp->cmd_cookiecnt; i++) {
            req->req_dataseg[i].d_count =
            sp->cmd_dmacookies[i].dmac_size;
            req->req_dataseg[i].d_base =
            sp->cmd_dmacookies[i].dmac_address;
            xfercount +=
        for (; i < ISP_NDATASEGS; i++) {
            req->req_dataseg[i].d_count = 0;
            req->req_dataseg[i].d_base = 0;
        pkt->pkt_resid = xfercount;
        if (sp->cmd_flags & CFLAG_DMASEND) {
            req->req_flags |= ISP_REQ_FLAG_DATA_WRITE;
        } else {
            req->req_flags |= ISP_REQ_FLAG_DATA_READ;
    } else {
        req->req_seg_count = 0;
        req->req_dataseg[0].d_count = 0;
    * Set up cdb in the request
    req->req_cdblen = sp->cmd_cdblen;
    bcopy((caddr_t)pkt->pkt_cdbp, (caddr_t)req->req_cdb,
    sp->cmd_cdblen);
    * Start the cmd.  If NO_INTR, must poll for cmd completion.
    if ((pkt->pkt_flags & FLAG_NOINTR) == 0) {
        mutex_enter(ISP_REQ_MUTEX(isp));
        rval = isp_i_start_cmd(isp, sp);
        mutex_exit(ISP_REQ_MUTEX(isp));
    } else {
        rval = isp_i_polled_cmd_start(isp, sp);
    return (rval);
Interrupt Handler and Command Completion
The interrupt handler must check the status of the device to be sure the device is generating the interrupt in question. The interrupt handler must also check for any errors that have occurred and service any interrupts generated by the device.
If data is transferred, the hardware should be checked to determine how much data was actually transferred. The pkt_resid field in the scsi_pkt(9S) structure should be set to the residual of the transfer.
Commands that are marked with the PKT_CONSISTENT flag when DMA resources are allocated through tran_init_pkt(9E) take special handling. The HBA driver must ensure that the data transfer for the command is correctly synchronized before the target driver's command completion callback is performed.
Once a command has completed, you need to act on two requirements:
Start a new command on the hardware, if possible, before calling the PKT_COMP command completion callback. The command completion handling can take considerable time. Typically, the target driver calls functions such as biodone(9F) and possibly scsi_transport(9F) to begin a new command.
The interrupt handler must return DDI_INTR_CLAIMED if this interrupt is claimed by this driver. Otherwise, the handler returns DDI_INTR_UNCLAIMED.
The following example shows an interrupt handler for the SCSI HBA isp driver. The caddr_t parameter is set up when the interrupt handler is added in attach(9E). This parameter is typically a pointer to the state structure, which is allocated on a per instance basis.
Example 18–9 HBA Driver Interrupt Handler
static u_int
isp_intr(caddr_t arg)
    struct isp_cmd         *sp;
    struct isp_cmd         *head, *tail;
    u_short                response_in;
    struct isp_response    *resp;
    struct isp             *isp = (struct isp *)arg;
    struct isp_slot        *isp_slot;
    int                    n;
    if (ISP_INT_PENDING(isp) == 0) {
        return (DDI_INTR_UNCLAIMED);
    do {
again:
        * head list collects completed packets for callback later
        head = tail = NULL;
        * Assume no mailbox events (e.g., mailbox cmds, asynch
        * events, and isp dma errors) as common case.
        if (ISP_CHECK_SEMAPHORE_LOCK(isp) == 0) {
            mutex_enter(ISP_RESP_MUTEX(isp));
            * Loop through completion response queue and post
            * completed pkts.  Check response queue again
            * afterwards in case there are more.
            isp->isp_response_in =
            response_in = ISP_GET_RESPONSE_IN(isp);
            * Calculate the number of requests in the queue
            n = response_in - isp->isp_response_out;
            if (n < 0) {
                n = ISP_MAX_REQUESTS -
                isp->isp_response_out + response_in;
            while (n-- > 0) {
                ISP_GET_NEXT_RESPONSE_OUT(isp, resp);
                sp = (struct isp_cmd *)resp->resp_token;
                * Copy over response packet in sp
                isp_i_get_response(isp, resp, sp);
            if (head) {
                tail->cmd_forw = sp;
                tail = sp;
                tail->cmd_forw = NULL;
            } else {
                tail = head = sp;
                sp->cmd_forw = NULL;
            ISP_SET_RESPONSE_OUT(isp);
            ISP_CLEAR_RISC_INT(isp);
            mutex_exit(ISP_RESP_MUTEX(isp));
            if (head) {
                isp_i_call_pkt_comp(isp, head);
        } else {
            if (isp_i_handle_mbox_cmd(isp) != ISP_AEN_SUCCESS) {
                return (DDI_INTR_CLAIMED);
            * if there was a reset then check the response
            * queue again
            goto again;
    } while (ISP_INT_PENDING(isp));
static void
    struct isp             *isp,
    struct isp_cmd         *head)
    struct isp             *isp;
    struct isp_cmd         *sp;
    struct scsi_pkt        *pkt;
    u_char                 status;
    while (head) {
        sp = head;
        pkt = sp->cmd_pkt;
        head = sp->cmd_forw;
        ASSERT(sp->cmd_flags & CFLAG_FINISHED);
        resp = &sp->cmd_isp_response;
        pkt->pkt_scbp[0] = (u_char)resp->resp_scb;
        pkt->pkt_state = ISP_GET_PKT_STATE(resp->resp_state);
        pkt->pkt_statistics = (u_long)
            ISP_GET_PKT_STATS(resp->resp_status_flags);
        pkt->pkt_resid = (long)resp->resp_resid;
        * If data was xferred and this is a consistent pkt,
        * do a dma sync
        if ((sp->cmd_flags & CFLAG_CMDIOPB) &&
            (pkt->pkt_state & STATE_XFERRED_DATA)) {
                DDI_DMA_SYNC_FORCPU);
        sp->cmd_flags = (sp->cmd_flags & ~CFLAG_IN_TRANSPORT) |
            CFLAG_COMPLETED;
        * Call packet completion routine if FLAG_NOINTR is not set.
        if (((pkt->pkt_flags & FLAG_NOINTR) == 0) &&
            pkt->pkt_comp) {
                (*pkt->pkt_comp)(pkt);
Timeout Handler
The HBA driver is responsible for enforcing time outs. A command must be complete within a specified time unless a zero time out has been specified in the scsi_pkt(9S) structure.
When a command times out, the HBA driver should mark the scsi_pkt(9S) with pkt_reason set to CMD_TIMEOUT and pkt_statistics OR'd with STAT_TIMEOUT. The HBA driver should also attempt to recover the target and bus. If this recovery can be performed successfully, the driver should mark the scsi_pkt(9S) using pkt_statistics OR'd with either STAT_BUS_RESET or STAT_DEV_RESET.
After the recovery attempt has completed, the HBA driver should call the command completion callback.
Note –
If recovery was unsuccessful or not attempted, the target driver might attempt to recover from the timeout by calling scsi_reset(9F).
The ISP hardware manages command timeout directly and returns timed-out commands with the necessary status. The timeout handler for the isp sample driver checks active commands for the time out state only once every 60 seconds.
The isp sample driver uses the timeout(9F) facility to arrange for the kernel to call the timeout handler every 60 seconds. The caddr_t argument is the parameter set up when the timeout is initialized at attach(9E) time. In this case, the caddr_t argument is a pointer to the state structure allocated per driver instance.
If timed-out commands have not been returned as timed-out by the ISP hardware, a problem has occurred. The hardware is not functioning correctly and needs to be reset.
