Writing Device Drivers
Opening Pipes
To open a pipe, pass to the usb_pipe_open(9F) function the endpoint descriptor that corresponds to the pipe you want to open. Use the usb_get_dev_data(9F) and usb_lookup_ep_data(9F) functions to retrieve the endpoint descriptor from the descriptor tree. The usb_pipe_open(9F) function returns a handle to the pipe.
You must specify a pipe policy when you open a pipe. The pipe policy contains an estimate of the number of concurrent asynchronous operations that require separate threads that will be needed for this pipe. An estimate of the number of threads is the number of parallel operations that could occur during a callback. The value of this estimate must be at least 2. See the usb_pipe_open(9F) man page for more information on pipe policy.
