STREAMS Programming Guide
Chapter 7 STREAMS Framework – Kernel Level
Because the STREAMS subsystem of UNIX® provides a framework on which communications services can be built, it is often called the STREAMS framework. This framework consists of the stream head and a series of utilities (put, putnext), kernel structures (mblk, dblk), and linkages (queues) that facilitate the interconnections between modules, drivers, and basic system calls. This chapter describes the STREAMS components from the kernel developer's perspective.
Overview of Streams in Kernel Space
Chapter 1, Overview of STREAMS describes a stream as a full-duplex processing and data transfer path between a STREAMS driver in kernel space and a process in user space. In the kernel, a stream consists of a stream head, a driver, and zero or more modules between the driver and the stream head.
The stream head is the end of the stream nearest the user process. All system calls made by user-level applications on a stream are processed by the stream head.
Messages are the containers in which data and control information is passed between the stream head, modules, and drivers. The stream head is responsible for translating the appropriate messages between the user application and the kernel. Messages are simply pointers to structures (mblk, dblk) that describe the data contained in them. Messages are categorized by type according to the purpose and priority of the message.
Queues are the basic elements by which the stream head, modules, and drivers are connected. Queues identify the open, close, put, and service entry points. Additionally, queues specify parameters and private data for use by modules and drivers, and are the repository for messages destined for deferred processing.
In the rest of this chapter, the word “modules” refers to modules, drivers, or multiplexers, except where noted.
Stream Head
The stream head interacts between applications in the user space and the rest of the stream in kernel space. The stream head is responsible for configuring the plumbing of the stream through open, close, push, pop, link, and unlink operations. It also translates user data into messages to be passed down the stream, and translates messages that arrive at the stream head into user data. Any characteristics of the stream that can be modified by the user application or the underlying stream are controlled by the stream head, which also informs users of data arrival and events such as error conditions.
If an application makes a system call with a STREAMS file descriptor, the stream head routines are invoked, resulting in data copying, message generation, or control operations. Only the stream head can copy data between the user space and kernel space. All other parts of the stream pass data by way of messages and are thus isolated from direct interaction with users of the stream.
Kernel–Level Messages
Chapter 3, STREAMS Application-Level Mechanisms discusses messages from the application perspective. The following sections discuss message types, message structure and linkage; how messages are sent and received; and message queues and priority from the kernel perspective.
Message Types
Several STREAMS messages differ in their purpose and queueing priority. The message types are briefly described and classified, according to their queueing priority, in Table 7–1 and Table 7–2. A detailed discussion of message types is in Chapter 8, STREAMS Kernel-Level Mechanisms.
Some message types are defined as high-priority types. Ordinary or normal messages can have a normal priority of 0, or a priority (also called a band) from 1 to 255.
Table 7–1 Ordinary Messages, Description of Communication Flow
Ordinary Messages
Direction
M_BREAK
Request to a stream driver to send a “break”
Upstream
M_CTL
Control or status request used for intermodule communication
Bidirectional
M_DATA
User data message for I/O system calls
Bidirectional
M_DELAY
Request for a real-time delay on output
Downstream
M_IOCTL
Control/status request generated by a stream head
Downstream
M_PASSFP
File pointer-passing message
Bidirectional
M_PROTO
Protocol control information
Bidirectional
M_SETOPTS
Sets options at the stream head; sends upstream
Upstream
M_SIG
Signal sent from a module or driver
Upstream
Table 7–2 High-Priority Messages, Description of Communication Flow
Direction
M_COPYIN
Copies in data for transparent ioctls
Upstream
M_COPYOUT
Copies out data for transparent ioctls
Upstream
M_ERROR
Reports downstream error condition
Upstream
M_FLUSH
Flushes module queue
Bidirectional
M_HANGUP
Sets a stream head hangup condition
Upstream
M_UNHANGUP
Reconnects line, sends upstream when hangup reverses
Upstream
M_IOCACK
Positive ioctl acknowledgement
Upstream
M_IOCDATA
Data for transparent ioctls, sent downstream
Downstream
M_IOCNAK
Negative ioctl acknowledgement
Upstream
M_PCPROTO
Bidirectional
M_PCSIG
Sends signal from a module or driver
Upstream
M_READ
Read notification; sends downstream
Downstream
M_START
Restarts stopped device output
Downstream
M_STARTI
Restarts stopped device input
Downstream
M_STOP
Suspends output
Downstream
M_STOPI
Suspends input
Downstream
Message Structure
A STREAMS message in its simplest form contains three elements—a message block, a data block, and a data buffer. The data buffer is the location in memory where the actual data of the message is stored. The data block (datab(9S) describes the data buffer—where it starts, where it ends, the message types, and how many message blocks reference it. The message block (msgb(9S)) describes the data block and how the data is used.
The data block has a typedef of dblk_t and has the following public elements:
struct datab {
	unsigned char       *db_base;          /* first byte of buffer */
	unsigned char       *db_lim;           /* last byte+1 of buffer */
	unsigned char        db_ref;           /* msg count ptg to this blk */
	unsigned char        db_type;          /* msg type */
typedef struct datab dblk_t;
The datab structure specifies the data buffers' fixed limits (db_base and db_lim), a reference count field (db_ref), and the message type field (db_type). db_base points to the address where the data buffer starts, db_lim points one byte beyond where the data buffer ends, and db_ref maintains a count of the number of message blocks sharing the data buffer.
Caution – Caution –
db_base, db_lim, and db_ref should not be modified directly. db_type is modified under carefully monitored conditions, such as changing the message type to reuse the message block.
In a simple message, the message block references the data block, identifying for each message the address where the message data begins and ends. Each simple message block refers to the data block to identify these addresses, which must be within the confines of the buffer such that db_baseb_rptr ≥≥ b_wptrdb_lim. For ordinary messages, a priority band can be indicated, and this band is used if the message is queued.
Figure 7–1 shows the linkages between msgb, datab, and the data buffer in a simple message.
Figure 7–1 Simple Message Referencing the Data Block
Diagram shows interactions of a simple message block with a data
block and data buffer.
The message block (see msgb(9S)) has a typedef of mblk_t and has the following public elements:
struct msgb {
	struct msgb            *b_next;      /*next msg in queue*/
	struct msgb            *b_prev;      /*previous msg in queue*/
	struct msgb            *b_cont;      /*next msg block of message*/
	unsigned char          *b_rptr;      /*1st unread byte in bufr*/
	unsigned char          *b_wptr;      /*1st unwritten byte in bufr*/
	struct datab           *b_datap;     /*data block*/
	unsigned char           b_band;      /*message priority*/
	unsigned short          b_flag;      /*message flags*/
The STREAMS framework uses the b_next and b_prev fields to link messages into queues. b_rptr and b_wptr specify the current read and write pointers respectively, in the data buffer pointed to by b_datap. The fields b_rptr and b_wptr are maintained by drivers and modules.
The field b_band specifies a priority band where the message is placed when it is queued using the STREAMS utility routines. This field has no meaning for high-priority messages and is set to zero for these messages. When a message is allocated using allocb(9F), the b_band field is initially set to zero. Modules and drivers can set this field to a value from 0 to 255 depending on the number of priority bands needed. Lower numbers represent lower priority. The kernel incurs overhead in maintaining bands if nonzero numbers are used.
Caution – Caution –
Message block data elements must not modify b_next, b_prev, or b_datap. The first two fields are modified by utility routines such as putq(9F) and getq(9F). Message block data elements can modify b_cont, b_rptr, b_wptr, b_band (for ordinary messages types), and b_flag.
The SunOS environment places b_band in the msgb structure. Some other STREAMS implementations place b_band in the datab structure. The SunOS implementation is more flexible because each message is independent. For shared data blocks, the b_band can differ in the SunOS implementation, but not in other implementations.
Message Linkage
A complex message can consist of several linked message blocks. If buffer size is limited or if processing expands the message, multiple message blocks are formed in the message, as shown in Figure 7–2. When a message is composed of multiple message blocks, the type associated with the first message block determines the overall message type, regardless of the types of the attached message blocks.
Figure 7–2 Linked Message Blocks
Diagram shows a complex message composed of linked message blocks.
Queued Messages
A put procedure processes single messages immediately and can pass the message to the next module's put procedure using put or putnext. Alternatively, the message is linked on the message queue for later processing, to be processed by a module's service procedure (putq(9F)). Note that only the first module of a set of linked modules is linked to the next message in the queue.
Think of linked message blocks as a concatenation of messages. Queued messages are a linked list of individual messages that can also be linked message blocks.
Figure 7–3 Queued Messages
Diagram shows three messages in a queue, one of which is linked.
In Figure 7–3 messages are queued: Message 1 being the first message on the queue, followed by Message 2 and Message 3. Notice that Message 1 is a linked message consisting of more than one mblk.
Caution – Caution –
Modules or drivers must not modify b_next and b_prev. These fields are modified by utility routines such as putq(9F) and getq(9F).
Shared Data
In Figure 7–4, two message blocks are shown pointing to one data block. db_ref indicates that there are two references (mblks) to the data block. db_base and db_lim point to an address range in the data buffer. The b_rptr and b_wptr of both message blocks must fall within the assigned range specified by the data block.
Figure 7–4 Shared Data Block
Diagram shows two message blocks that share a common data block
and data buffer.
Data blocks are shared using utility routines (see dupmsg(9F) or dupb(9F)). STREAMS maintains a count of the message blocks sharing a data block in the db_ref field.
These two mblks share the same data and datablock. If a module changes the contents of the data or message type, it is visible to the owner of the message block.
When modifying data contained in the dblk or data buffer, if the reference count of the message is greater than one, the module should copy the message using copymsg(9F), free the duplicated message, and then change the appropriate data.
Note –
Hardening Information. At Sun, it is assumed that a message with a db_ref > 1 is a “read-only” message and can be read but not modified. If the module wishes to modify the data, it should first copy the message, and free the original:
if ( dbp->db_ref > 1 ) {
	dblk_t	*newdbp;
	/* Get a copy of the message */
	newdbp = copymsg(dbp);
	/* Free the original */
	freemsg(dbp);
	/* make sure that we are now using the new dbp */
	dbp = newdbp;
STREAMS provides utility routines and macros (identified in Appendix B, Kernel Utility Interface Summary) to assist in managing messages and message queues, and in other areas of module and driver development. Always use utility routines to operate on a message queue or to free or allocate messages. If messages are manipulated in the queue without using the STREAMS utilities, the message ordering can become confused and cause inconsistent results.
Caution – Caution –
Not adhering to the DDI/DKI can result in panics and system crashes.
Sending and Receiving Messages
Among the message types, the most commonly used messages are M_DATA, M_PROTO, and M_PCPROTO. These messages can be passed between a process and the topmost module in a stream, with the same message boundary alignment maintained between user and kernel space. This allows a user process to function, to some degree, as a module above the stream and maintain a service interface. M_PROTO and M_PCPROTO messages carry service interface information among modules, drivers, and user processes.
Modules and drivers do not interact directly with any interfaces except open(2) and close(2). The stream head translates and passes all messages between user processes and the uppermost STREAMS module. Message transfers between a process and the stream head can occur in different forms. For example, M_DATA and M_PROTO messages can be transferred in their direct form by getmsg(2) and putmsg(2). Alternatively, write(2) creates one or more M_DATA messages from the data buffer supplied in the call. M_DATA messages received at the stream head are consumed by read(2) and copied into the user buffer.
Any module or driver can send any message in either direction on a stream. However, based on their intended use in STREAMS and their treatment by the stream head, certain messages can be categorized as upstream, downstream, or bidirectional. For example, M_DATA, M_PROTO, or M_PCPROTO messages can be sent in both directions. Other message types such as M_IOACK are sent upstream to be processed only by the stream head. Messages to be sent downstream are silently discarded if received by the stream head. Table 7–1 and Table 7–2 indicate the intended direction of message types.
STREAMS enables modules to create messages and pass them to neighboring modules. read(2) and write(2) are not enough to enable a user process to generate and receive all messages. In the first place, read(2) and write(2) are byte-stream oriented with no concept of message boundaries. The message boundary of each service primitive must be preserved so that the start and end of each primitive can be located in order to support service interfaces. Furthermore, read(2) and write(2) offer only one buffer to the user for transmitting and receiving STREAMS messages. If control information and data is placed in a single buffer, the user has to parse the contents of the buffer to separate the data from the control information. Furthermore, read(2) and write(2) offer only one buffer to the user for transmitting and receiving STREAMS messages. If control information and data is placed in a single buffer, the user has to parse the contents of the buffer to separate the data from the control information.
getmsg(2) and putmsg(2) enable a user process and the stream to pass data and control information between one another while maintaining distinct message boundaries.
Data Alignment
Note –
Hardening Information. There is no guarantee in STREAMS that a b_rptr or b_wptr will fall on a proper bit alignment. Most modules that pass data structures with pointers try to retain the desired bit alignment. If the module is in a stream where this is reasonably guaranteed, it does not need to check data alignment. However, for the purpose of hardening, modules that are concerned about data alignment should verify that pointers are properly aligned, or copy data in mblks to local structures that are properly aligned (see bcopy(3C)).
Note –
Hardening Information. Ensure that the changing of pointers is uniform (b_rptr <= b_rptr). Keep pointers inside db_base and db_lim. It is easier to recover from an error if b_rptr and b_wptr are inside db_base and db_lim.
When a module changes the b_rptr and/or the b_wptr, it should verify the following relationship:
db_base <= b_rptr <= b_wptr <= db_lim
and
db_base < db_lim
Message Queues and Message Priority
Message queues grow when the STREAMS scheduler is delayed from calling a service procedure by system activity, or when the procedure is blocked by flow control. When called by the scheduler, a module's service procedure processes queued messages in a FIFO manner (getq(9F)). However, some messages associated with certain conditions, such as M_ERROR, must reach their stream destination as rapidly as possible. This is accomplished by associating priorities with the messages. These priorities imply a certain ordering of messages in the queue, as shown in Figure 7–5.
Each message has a priority band associated with it. Ordinary messages have a priority band of zero. The priority band of high-priority messages is ignored since they are high priority and thus not affected by flow control. putq(9F) places high-priority messages at the head of the message queue, followed by priority band messages (expedited data) and ordinary messages.
Figure 7–5 Message Ordering in a Queue
Diagram shows how messages are ordered in a queue according to
priority.
When a message is queued, it is placed after the messages of the same priority already in the queue (in other words, FIFO within their order of queueing). This affects the flow-control parameters associated with the band of the same priority. Message priorities range from 0 (normal) to 255 (highest). This provides up to 256 bands of message flow within a stream. An example of how to implement expedited data would be with one extra band of data flow (priority band 1), is shown in the following figure. Queues are explained in detail in the next section.
Figure 7–6 Message Ordering with One Priority Band
Diagram shows a message queue with expedited messages.
High-priority messages are not subject to flow control. When they are queued by putq(9F), the associated queue is always scheduled, even if the queue has been disabled (noenable(9F)). When the service procedure is called by the stream's scheduler, the procedure uses getq(9F) to retrieve the first message on queue, which is a high-priority message. Service procedures must be implemented to act on high-priority messages immediately. The mechanisms just mentioned—priority message queueing, absence of flow control, and immediate processing by a procedure—result in rapid transport of high-priority messages between the originating and destination components in the stream.
In general, high-priority messages should be processed immediately by the module's put procedure and not placed on the service queue.
Caution – Caution –
A service procedure must never queue a high-priority message on its own queue because an infinite loop results. The enqueuing triggers the queue to be immediately scheduled again.
Message Queues
The queue is the fundamental component of a stream. It is the interface between a STREAMS module and the rest of the stream, and is the repository for deferred message processing. For each instance of an open driver or pushed module or stream head, a pair of queues is allocated, one for the read side of the stream and one for the write side.
The RD(9F), WR(9F), and otherq(9F) routines allow reference of one queue from the other. Given a queue, RD(9F) returns a pointer to the read queue, WR(9F) returns a pointer to the write queue and otherq(9F) returns a pointer to the opposite queue of the pair (see queue(9S)).
By convention, queue pairs are depicted graphically as side- by-side blocks, with the write queue on the left and the read queue on the right (see following figure).
Figure 7–7 Queue Pair Allocation
Diagram shows an allocated queue pair, one for the read side
queue() Structure
As previously discussed, messages are ordered in message queues. Message queues, message priority, service procedures, and basic flow control all combine in STREAMS. A service procedure processes the messages in its queue. If there is no service procedure for a queue, putq(9F) does not schedule the queue to be run. The module developer must ensure that the messages in the queue are processed. Message priority and flow control are associated with message queues.
The queue structure is defined in stream.h as a typedef queue_t, and has the following public elements:
struct  qinit   *q_qinfo;	/* procs and limits for queue */
struct  msgb    *q_first;	/* first data block */
struct  msgb    *q_last;	/* last data block */
struct  queue   *q_next;	/* Q of next stream */
struct  queue   *q_link;	/* to next Q for scheduling */
void            *q_ptr;		/* to private data structure */
size_t          q_count;	/* number of bytes on Q */
uint            q_flag;		/* queue state */
ssize_t         q_minpsz;	/* min packet size accepted by this module */
ssize_t         q_maxpsz;	/* max packet size accepted by this module */
size_t          q_hiwat;	/* queue high–water mark */
size_t          q_lowat;	/* queue low–water mark */
q_first points to the first message on the queue, and q_last points to the last message on the queue. q_count is used in flow control and contains the total number of bytes contained in normal and high-priority messages in band 0 of this queue. Each band is flow controlled individually and has its own count. For more details, see qband Structure. qsize(9F) can be used to determine the total number of messages on the queue. q_flag indicates the state of the queue. See Table 7–3 for the definitions of these flags.
q_minpsz contains the minimum packet size accepted by the queue, and q_maxpsz contains the maximum packet size accepted by the queue. These are suggested limits, and some implementations of STREAMS may not enforce them. The SunOS stream head enforces these values but they are voluntary at the module level. You should design modules to handle messages of any size.
q_hiwat indicates the limiting maximum number of bytes that can be put on a queue before flow control occurs. q_lowat indicates the lower limit where STREAMS flow control is released.
q_ptr is the element of the queue structure where modules can put values or pointers to data structures that are private to the module. This data can include any information required by the module for processing messages passed through the module, such as state information, module IDs, routing tables, and so on. Effectively, this element can be used any way the module or driver writer chooses. q_ptr can be accessed or changed directly by the driver, and is typically initialized in the open(9E) routine.
When a queue pair is allocated, streamtab initializes q_qinfo, and module_info initializes q_minpsz, q_maxpsz, q_hiwat, and q_lowat. Copying values from the module_info structure enables them to be changed in the queue without modifying the streamtab and module_info values.
The following table lists the queue(9S) flags.
Table 7–3 Queue Flags
Flag
Description
QENAB
The queue is enabled to run the service procedure
QWANTR
Someone wants to read queue
QWANTW
Someone wants to write to queue
QFULL
The queue is full
QREADR
Set for all read queues
QUSE
This queue in use (allocation)
QNOENB
Do not enable the queue when data is placed on it
Using Queue Information
The q_first, q_last, q_count, and q_flags components must not be modified by the module, and should be accessed using strqget(9F). The values of q_minpsz, q_maxpsz, q_hiwat, and q_lowat are accessed through strqget(9F), and are modified by strqset(9F). q_ptr can be accessed and modified by the module and contains data private to the module.
All other accesses to fields in the queue(9S) structure should be made through STREAMS utility routines (see Appendix B, “STREAMS Utilities”). Modules and drivers should not change any fields not explicitly listed previously.
strqget(9F) enables modules and drivers to get information about a queue or particular band of the queue. This insulates the STREAMS data structures from the modules and drivers. The prototype for the strqget(9F) routine is:
int
strqget(queue_t *q, qfields_t what, unsigned char pri, void *valp)
q specifies from which queue the information is to be retrieved; what defines the queue_t field value to obtain (see the following structure fields). pri identifies a specific priority band. The value of the field is returned in valp. The fields that can be obtained are defined in <sys/stream.h> and shown here as:
QHIWAT              /* high–water mark */
QLOWAT              /* low–water mark */
QMAXPSZ             /* largest packet accepted */
QMINPSZ             /* smallest packet accepted */
QCOUNT              /* approx. size (in bytes) of data */
QFIRST              /* first message */
QLAST               /* last message */
QFLAG               /* status */
strqset(9F) enables modules and drivers to change information about a queue or a band of the queue. This also insulates the STREAMS data structures from the modules and drivers. Its prototype is:
int
strqset(queue_t *q. qfields_t what, unsigned char pri, intptr_t val)
The q, what, and pri fields are the same as in strqget(9F), but the information to be updated is provided in val instead of through a pointer. If the field is read-only, EPERM is returned and the field is left unchanged. The following fields are read-only: QCOUNT, QFIRST, QLAST, and QFLAG.
Note –
Hardening Information. Access queue structure information, through strqget() and strqset() only. Do not access the queue structure directly.
Entry Points
The q_qinfo component points to a qinit structure. This structure defines the module's entry point procedures for each queue, which include the following:
int        (*qi_putp)();       /* put procedure */
int        (*qi_srvp)();       /* service procedure */
int        (*qi_qopen)();      /* open procedure */
int        (*qi_qclose)();     /* close procedure */
struct module_info *qi_minfo;  /* module information structure */
There is generally a unique q_init structure associated with the read queue and the write queue. qi_putp identifies the put procedure for the module. qi_srvp identifies the optional service procedure for the module.
The open and close entry points are required for the read-side queue. The put procedure is generally required on both queues and the service procedure is optional.
Note –
Hardening Information. If the put procedure is not defined and a subsequent put is done to the module, a panic occurs. As a precaution, putnext should be declared as the module's put procedure.
If a module only requires a service procedure, putq(9F) can be used as the module's put procedure. If the service procedure is not defined, the module's put procedure must not queue data (putq).
The qi_qopen member of the read-side qinit structure identifies the open(9E) entry point of the module. The qi_qclose member of the read-side qinit structure identifies the close(9E) entry point of the module.
The qi_minfo member points to the module_info(9S) structure.
struct module_info {
		ushort   mi_idnum;          /* module id number */
		char     *mi_idname;        /* module name */
		ssize_t  mi_minpsz;         /* min packet size accepted */
		ssize_t  mi_maxpsz;         /* max packet size accepted */
		size_t   mi_hiwat;          /* hi-water mark */
		size_t   mi_lowat;          /* lo-water mark */
mi_idnum is the module's unique identifier defined by the developer and used in strlog(9F). mi_idname is an ASCII string containing the name of the module. mi_minpsz is the initial minimum packet size of the queue. mi_maxpsz is the initial maximum packet size of the queue. mi_hiwat is the initial high–water mark of the queue. mi_lowat is the initial low–water mark of the queue.
open Routine
The open(9E) routine of a device is called once for the initial open of the device, then is called again on subsequent reopens of the stream. Module open routines are called once for the initial push onto the stream and again on subsequent reopens of the stream.
Figure 7–8 Order of a Module's open Procedure
Diagram shows a stream consisting of three modules. This example
is used to describe the order in which the modules call the open routine.
The stream is analogous to a stack. Initially the driver is opened and as modules are pushed onto the stream, their open routines are invoked. Once the stream is built, this order reverses if a reopen of the stream occurs. For example, while building the stream shown in Figure 7–8, device A's open routine is called, followed by B's and C's when they are pushed onto the stream. If the stream is reopened, Module C's open routine is called first, followed by B's, and finally by A's.
Usually the module or driver does not check this, but the issue is raised so that dependencies on the order of open routines are not introduced by the programmer. Note that although an open can happen more than once, close is only called once. See the next section on the close routine for more details. If a file is duplicated (dup(2)) the stream is not reopened.
The prototype for the open entry point is:
int prefix_open(queue_t *q, dev_t *devp, int oflag, int sflag,
						cred_t *cred_p)
q
Pointer to the read queue of this module.
devp
Pointer to a device number that is always associated with the device at the end of the stream. Modules cannot modify this value, but drivers can, as described in Chapter 9, STREAMS Drivers.
oflag
For devices, oflag can contain the following bit mask values: FEXCL, FNDELAY, FREAD, and FWRITE. See Chapter 9, STREAMS Drivers for more information on drivers.
sflag
When the open is associated with a driver, sflag is set to 0 or CLONEOPEN, see Chapter 9, STREAMS Drivers, Cloning STREAMS Drivers for more details. If the open is associated with a module, sflag contains the value MODOPEN.
cred_p
Pointer to the user credentials structure.
The open routines to devices are serialized . If more than one process attempts to open the device, only one proceeds and the others wait until the first finishes. Interrupts are not blocked during an open. The driver's interrupt routine must continue to handle interrupts when multiple processes are opening the same device. See Chapter 9, STREAMS Drivers for more information.
The open routines for both drivers and modules have user context. For example, they can do blocking operations, but the blocking routine should return in the event of a signal. In other words, q_wait_sig is allowed, but q_wait is not.
If the module or driver is to allocate a controlling terminal, it should send an M_SETOPTS message with SO_ISTTY set to the stream head.
The open routine usually initializes the q_ptr member of the queue. q_ptr is generally initialized to some private data structure that contains various state information private to the module or driver. The module's close routine is responsible for freeing resources allocated by the module including q_ptr. The following example shows a simple open routine.
Example 7–1 A Simple open Routine
/* example of a module open */
int xx_open(queue_t *q, dev_t *devp, int oflag, int sflag, cred_t *crp)
	struct xxstr *xx_ptr;
	xx_ptr = kmemzalloc(sizeof(struct xxstr), KM_SLEEP);
	xx_ptr->xx_foo = 1;
	q->q_ptr = WR(q)->q_ptr = xx_ptr;
	qprocson(q);
	return (0);
In a multithreaded environment, data can flow up the stream during the open. A module receiving this data before its open routine finishes initialization can panic. To eliminate this problem, modules and drivers are not linked into the stream until qprocson(9F) is called (messages flow around the module). The following figure illustrates this process. See Chapter 12, Multithreaded STREAMS for more information on the multithreaded environment and the use of perimeters.
Figure 7–9 Messages Flowing Around the Module Before qprocson
Diagram shows how a module is linked after qprocon is called.
The module or driver instance is guaranteed to be single-threaded before qprocson(9F) is called, except for interrupts or callbacks that must be handled separately.
Note –
Hardening Information. qprocson must be called before calling qbufcall(9F), qtimeout(9F), qwait(9F), or qwait_sig(9F).
Before a module calls qprocson, it must be ready to accept data via the module's put procedure so all data structures must be fully initialized (see put Procedure). The most common method for calling qprocson is to call this function just before returning from a successful open (see Example 7–1).
Note –
For a multithreaded environment, verify you are using the correct perimeter before accessing data. See Chapter 12, Multithreaded STREAMS for more information on the multithreaded environment and the use of perimeters.
close Routine
The close routine of devices is called only during the last close of the device. Module close routines are called during the last close or if the module is popped.
The prototype for the close entry point is:
int prefix_close (queue *q, int flag, cred_t * cred_p)
q
is a pointer to the read queue of the module.
flag
is analogous to the oflag parameter of the open entry point. If FNBLOCK or FNDELAY is set, then the module should attempt to avoid blocking during the close.
cred_p
is a pointer to the user credential structure.
Like open, the close entry point has user context and can block. The blocking routines should return in the event of a signal. Device drivers must take into consideration that interrupts are not blocked during close.
close might be called in a context where a thread cannot receive signals, such as calling close during exit closure of open file descriptors. The system does not reawaken the thread when a user-level process attempts to send a signal, including SIGKILL, to the process.
Use ddi_can_receive_sig to determine whether a thread can receive user-level signals. ddi_can_receive_sig returns B_TRUE if the current thread can receive user-level signals, and B_FALSE if the thread cannot. In this case, qwait_sig behaves exactly like qwait. Use qtimeout or other facilities to prevent close from blocking indefinitely when a thread cannot receive signals.
In particular, asynchronous serial drivers should use caution when draining output data after calling close. Under most conditions, the driver must attempt to wait as long as possible to drain all output data and to discard the data only when a signal is received. However, if ddi_can_receive_sig returns B_FALSE and output flow control is asserted indefinitely by the peer, the driver must abort the drain operation after a reasonable time period has elapsed. Otherwise, the device could remain unusable until the next system boot.
The close routine must cancel all pending and qbufcall callbacks, and process any remaining messages on its service queue. In Example 7–2, the open and close procedures are only used on the read side of the queue and can be set to NULL in the write-side qinit structure initialization.
Example 7–2 Example of a Module Close
/* example of a module close */
static int
xx_close(queue_t *, *rq, int flag, cred_t *credp)
		struct xxstr   *xxp;
    * Disable xxput() and xxsrv() procedures on this queue.
		qprocsoff(rq);
		xxp = (struct xxstr *) rq->q_ptr;
    * Cancel any pending timeout.
    * This example assumes that the timeout was issued
    * against the write queue.
		if (xxp->xx_timeoutid != 0) {
			(void) quntimeout(WR(rq), xxp->xx_timeoutid);
			xxp->xx_timeoutid=0;
    * Cancel any pending bufcalls.
    * This example assumes that the bufcall was issued
		if (xxp->xx_bufcallid !=0) {
			(void) qunbufcall(WR(rq), xxp->xx_bufcallid);
 		xxp->xx_bufcallid = 0;
		rq->q_ptr = WR(rq)->q_ptr = NULL;
    * Free resources allocated during open
		kmem_free (xxp, sizeof (struct xxstr));
		return (0);
qprocsoff does the inverse operation shown in Figure 7–9. This supports the need for cancelling callbacks before a qprocsoff.
qprocsoff is typically called at the begining of the close routine. The module can no longer receive messages from adjoining modules. The queue, however, still has pointers to it's adjoining modules and can putnext. However, as the queue is no longer inserted into the stream, these messages may be out of order from other messages in the stream, so it is best to process these messages before qprocsoff.
qwait is used because a module needs to get some response from another module or driver in the STREAM (i.e. a DLPI disconnect message sent downstream). qwait and qwait_sig must also be called before qprocsoff because once the queue is removed from the stream, there will be no way for the reply message to reach the queue.
put Procedure
The put procedure is the mechanism that other modules use to pass messages into this module. This procedure is called via the putor putnext routines on behalf of other modules. The queue's put procedure is invoked by the preceding module to process a message immediately (see put(9F) and putnext(9F)). Most modules will have a put routine. The common exception is on the read-side of drivers because there will not typically be a module downstream to the driver.
Note –
Hardening Information. putnext is used by adjoining modules to ensure that the next module's queue is intact. Use of put cannot guarantee that the queue being called is currently valid and inserted into a stream; you must ensure that the queue is valid when using put.
A driver's put procedure must do one of the following:
All M_IOCTL type messages must be acknowledged through M_IOACK or rejected through M_IOCNACK. M_IOCTL messages should not be freed. Drivers must free any unrecognized message.
A module's put procedure must do one of the following as shown in Figure 7–10:
Unrecognized messages are passed to the next module or driver. The stream operates more efficiently when messages are processed in the put procedure. Processing a message with the service procedure imposes some latency on the message.
Figure 7–10 Flow of put Procedure
Flow diagram shows how a module processes messages using the
put procedure.
If the next module is flow controlled (see canput(9F) and canputnext(9F)), the put procedure can queue the message for processing by the next service procedure (see putq(9F)). The put routine is always called before the component's corresponding srv(9E) service routine, so always use put for immediate message processing.
Note –
Hardening Information. canput and canputnext operate similar to put and putnext; that is the next functions verify the integrity of the next queue. Not using the next functions can cause panics as the queue being referenced might have already been closed.
The preferred naming convention for a put procedure reflects the direction of the message flow. The read put procedure is suffixed by r (rput), and the write procedure by w (wput). For example, the read-side put procedure for module xx is declared as int xxrput (queue_t *q, mblk_t *mp). The write-side put procedure is declared as int xxwput(queue_t *q, mblk_t *mp), where q points to the corresponding read or write queue and mp points to the message to be processed.
Although high-priority messages can be placed on the service queue, processing them immediately in the put procedure is better. (See the stub code in Example 7–3.) Place ordinary or priority-band messages on the service queue (putq(9F)) if:
If other messages already exist on the queue and the put procedure does not queue new messages (provided they are not high-priority), messages are reordered. If the next module is flow controlled (see canput(9F) and canputnext(9F)), the put procedure can queue the message for processing by the service procedure (see putq(9F)).
Example 7–3 Example of a Module put Procedure
/*example of a module put procedure */
int
xxrput(queue_t *,mblk_t, *mp)
    * If the message is a high-priority message or
    * the next module is not flow controlled and we have not
    * already deferred processing, then:
    if (mp->b_datap->db_type >= QPCTL ||
             (canputnext(q) && q->q_first == NULL)) {
         * Process message
         putnext(q,mp);
    } else {
          * put message on service queue
          putq(q,mp);
     return (0);
Put procedures must never call putq, putbq, or qenable if the module does not have a service procedure.
Note –
Hardening Information. Once a message is passed using a putq, put, putnext, as well as the perimeter function qwriter, it cannot be accessed again because the use of this message has been given to the new routine. If a reference needs to be retained by the module, it should copy it by using copyb, copymsg, dupb, or dupmsg.
A module need not process the message immediately, and can queue it for later processing by the service procedure (see putq(9F)).
The SunOS STREAMS framework is multithreaded. Unsafe (nonmultithreaded) modules are not supported. To make multithreading of modules easier, the SunOS STREAMS framework uses perimeters (see MT STREAMS Perimeters for more information).
Caution – Caution –
Mutex locks must not be held across a call to put(9F), putnext(9F), or qreply(9F).
Because of the asynchronous nature of STREAMS, do not assume that a module's put procedure has been called just because put(9F), putnext(9F), or qreply(9F) has returned.
Queue service Procedure
A queue's service procedure is invoked to process messages on the queue. It removes successive messages from the queue, processes them, and calls the put procedure of the next module in the stream to give the processed message to the next queue.
The service procedure is optional. A module or driver can use a service procedure for the following reasons:
The service procedure is invoked by the STREAMS scheduler. A STREAMS service procedure is scheduled to run if:
A service procedure usually processes all messages on its queue (getq(9F)) or takes appropriate action to ensure it is re-enabled (qenable(9F)) at a later time. Figure 7–11 shows the flow of a service procedure.
Caution – Caution –
High-priority messages (db_type and MSG_HIPRI) must never be placed back on a service queue (putbq(9F)). Placing these messages in a service queue can cause an infinite loop.
Figure 7–11 Flow of service Procedure
Flow diagram shows how the service procedure processes messages.
The following example shows the stub code for a module service procedure.
Example 7–4 Module service Procedure
/*example of a module service procedure */
int
xxrsrv(queue_t *q)
		mblk_t *mp;
    * While there are still messages on our service queue
		while ((mp = getq(q) != NULL) {
       * We check for high priority messages, but
       * none is ever seen since the put procedure
       * never queues them.
       * If the next module is not flow controlled, then
      if (mp->b_datap->db_type >= QPCTL || (canputnext (q)) {
				 * process message
				putnext (q, mp);
			} else {
          * put message back on service queue
				putbq(q,mp);
				break;
		return (0);
qband Structure
The queue flow information for each band, other than band 0, is contained in a qband(9S) structure. This structure is not visible to other modules. For accessible information see strqget(9F) and strqset(9F). qband is defined as follows:
typedef struct qband {
		struct  qband    *qb_next;   /* next band's info */
		size_t  qb_count;            /* number of bytes in band */
		struct  msgb     *qb_first;  /* beginning of band's data */
		struct  msgb     *qb_last;   /* end of band's data */
		size_t  qb_hiwat;            /* high-water mark for band */
		size_t  qb_lowat;            /* low–water mark for band */
		uint    qb_flag;             /* see below */
} qband_t;
The structure contains pointers to the linked list of messages in the queue. These pointers, qb_first and qb_last, denote the beginning and end of messages for the particular band. The qb_count field is analogous to the queue's q_count field. However, qb_count only applies to the messages in the queue in the band of data flow represented by the corresponding qband structure. In contrast, q_count only contains information regarding normal and high-priority messages.
Each band has a separate high and low watermark, qb_hiwat and qb_lowat. These are initially set to the queue's q_hiwat and q_lowat respectively. Modules and drivers can change these values through the strqset(9F) function. The QB_FULL flag for qb_flag denotes that the particular band is full.
The qband(9S) structures are not preallocated per queue. Rather, they are allocated when a message with a priority greater than zero is placed in the queue using putq(9F), putbq(9F), or insq(9F). Since band allocation can fail, these routines return 0 on failure and 1 on success. Once a qband(9S) structure is allocated, it remains associated with the queue until the queue is freed. strqset(9F) and strqget(9F) cause qband(9S) allocation. Sending a message to a band causes all bands up to and including that one to be created.
Using qband Information
The STREAMS utility routines should be used when manipulating the fields in the queue and qband(9S) structures. strqget(9F) and strqset(9F) are used to access band information.
Drivers and modules can change the qb_hiwat and qb_lowat fields of the qband structure. Drivers and modules can only read the qb_count, qb_first, qb_last, and qb_flag fields of the qband structure. Only the fields listed previously can be referenced.
Caution – Caution –
There are fields in the qband structure that are reserved and are not documented. These fields are subject to undocumented, unnotified change at any time.
The following figure shows a queue with two extra bands of flow.
Figure 7–12 Data Structure Linkage
Diagram shows the data structure linkage of a queue with two
Several routines are provided to aid you in controlling each priority band of data flow. These routines are
flushband(9F) is discussed in Flushing Priority Band. bcanputnext(9F) is discussed in Flow Control in Service Procedures, and the other two routines are described in the following section. Appendix B, Kernel Utility Interface Summary also has a description of these routines.
Message Processing Procedures
Typically, put procedures are required in pushable modules, but service procedures are optional. If the put routine queues messages, a corresponding service routine must be present to handle the queued messages. If the put routine does not queue messages, the service routine is not required.
Figure 7–10 shows typical processing flow for a put procedure which works as follows:
Figure 7–11 shows typical processing flow for a service procedure that works as follows:
Caution – Caution –
A service or put procedure must never block since it has no user context. It must always return to its caller.
If no processing is required in the put procedure, the procedure does not have to be explicitly declared. Rather, putq(9F) can be placed in the qinit(9S) structure declaration for the appropriate queue side to queue the message for the service procedure. For example:
static struct qinit winit = { putq, modwsrv, ...... };
More typically, put procedures process high-priority messages to avoid queueing them.
Device drivers associated with hardware are examples of STREAMS devices that might not have a put procedure. Since there are no queues below the hardware level, another module does not call the module's put procedure. Data comes into the stream from an interrupt routine, and is either processed or queued for the service procedure.
A STREAMS filter is an example of a module without a service procedure—messages passed to it are either passed or filtered. Flow control is described in Flow Control in Service Procedures.
The key attribute of a service procedure in the STREAMS architecture is delayed processing. When a service procedure is used in a module, the module developer is implying that there are other, more time-sensitive activities to be performed elsewhere in this stream, in other streams, or in the system in general.
Note –
The presence of a service procedure is mandatory if the flow control mechanism is to be utilized by the queue. If you do not implement flow control, queues can overflow and hang the system.
The STREAMS flow control mechanism is voluntary and operates between the two nearest queues in a stream containing service procedures (see Figure 7–13). Messages are held on a queue only if a service procedure is present in the associated queue.
Messages accumulate on a queue when the queue's service procedure processing does not keep pace with the message arrival rate, or when the procedure is blocked from placing its messages on the following STREAMS component by the flow control mechanism. Pushable modules can contain independent upstream and downstream limits. The stream head contains a preset upstream limit (which can be modified by a special message sent from downstream) and a driver can contain a downstream limit. See M_SETOPTS for more information.
Flow control operates as follows:
Figure 7–13 Flow Control Mechanism
Diagram shows three queues in a stream, two of which have service
procedures for hadling message queues.
Modules and drivers need to observe the message priority. High-priority messages, determined by the type of the first block in the message,
are not subject to flow control. They should be processed immediately and forwarded, as appropriate.
For ordinary messages, flow control must be tested before any processing is performed. canputnext(9F) determines if the forward path from the queue is blocked by flow control.
This is the general flow control processing of ordinary messages:
Caution – Caution –
High-priority messages must be processed and not placed back on the queue.
The canonical representation of this processing within a service procedure is:
while (getq() != NULL)
	if (high priority message || no flow control) {
		process message
		putnext()
	} else {
		putbq()
		return
Expedited data has its own flow control with the same processing method as that of ordinary messages. bcanputnext(9F) provides modules and drivers with a test of flow control in a priority band. It returns 1 if a message of the given priority can be placed in the queue. It returns 0 if the priority band is flow controlled. If the band does not exist in the queue in question, the routine returns 1.
If the band is flow controlled, the higher bands are not affected. However, lower bands are also stopped from sending messages. Without this, lower priority messages can be passed along ahead of the flow-controlled higher priority messages.
The call bcanputnext(q, 0); is equivalent to the call canputnext(q);.
Note –
A service procedure must process all messages in its queue unless flow control prevents this.
A service procedure must continue processing messages from its queue until getq(9F) returns NULL. When an ordinary message is queued by putq(9F), the service procedure is scheduled only if the queue was previously empty, and a previous getq(9F) call returns NULL (that is, the QWANTR flag is set). If there are messages in the queue, putq(9F) presumes the service procedure is blocked by flow control and the procedure is automatically rescheduled by STREAMS when the block is removed. If the service procedure cannot complete processing as a result of conditions other than flow control (for example, no buffers), it must ensure a later return (for example, by bufcall(9F)) or discard all messages in the queue. If this is not done, STREAMS never schedules the service procedure to be run unless the queue's put procedure queues a priority message with putq(9F).
Note –
High-priority messages are discarded only if there is already a high-priority message on the stream head read queue. That is, there can be only one high-priority message (PC_PROTO) present on the stream head read queue at any time.
putbq(9F) replaces a message at the beginning of the appropriate section of the message queue according to its priority. This might not be the same position at which the message was retrieved by the preceding getq(9F). A subsequent getq(9F) might return a different message.
putq(9F) checks only the priority band in the first message. If a high-priority message is passed to putq with a nonzero b_band value, b_band is reset to 0 before placing the message in the queue. If the message is passed to putq(9F) with a b_band value that is greater than the number of qband(9S)structures associated with the queue, putq(9F) tries to allocate a new qband(9S) structure for each band, up to and including the band of the message.
rmvq and insq work similarly. If you try to insert a message out of order in a queue with insq(9F), the message is not inserted and the routine fails.
putq(9F) does not schedule a queue if noenable(9F) was previously called for the queue. noenable(9F) forces putq(9F) to queue the message when called by this queue, but not to schedule the service procedure. noenable(9F) does not prevent the queue from being scheduled by a flow control back-enable. The inverse of noenable(9F) is enableok(9F).
The service procedure is written using the following algorithm:
while ((bp = getq(q)) != NULL) {
	if (queclass (bp) == QPCTL) {
		/* Process the message */
		putnext(q, bp);
	 } else if (bcanputnext(q, bp->b_band)) {
		putnext(q, bp);
	 } else {
		putbq(q, bp);
		return;
If the module or driver ignores priority bands, the algorithm is the same as described in the previous paragraphs, except that canputnext(q) is substituted for bcanputnex(q, bp->b_band).
qenable(9F), another flow-control utility, enables a module or driver to cause one of its queues, or another module's queues, to be scheduled. qenable(9F) can also be used to delay message processing. An example of this is a buffer module that gathers messages in its message queue and forwards them as a single, larger message. This module uses noenable(9F) to inhibit its service procedure and queues messages with its put procedure until a certain byte count or “in queue” time has been reached. When either of these conditions is met, the module calls qenable(9F) to cause its service procedure to run.
Another example is a communication line discipline module that implements end-to-end (for example, to a remote system) flow control. Outbound data is held on the write side message queue until the read side receives a transmit window from the remote end of the network.
Note –
STREAMS routines are called at different priority levels. Interrupt routines are called at the interrupt priority of the interrupting device. Service routines are called with interrupts enabled (so that service routines for STREAMS drivers can be interrupted by their own interrupt routines).
