STREAMS Programming Guide
System Calls Used
Table 4-1 summarizes the system calls commonly used in controlling and transferring data and messages within a stream.
Table 4–1 System Calls Used
System Call
Description
read(2)
Reads data from a stream
write(2)
Writes data to a stream
ioctl(2)
Controls a stream
getmsg(2)
Receives a message at the stream head
getpmsg(2)
Receives a priority message at the stream head
putmsg(2)
Sends a message downstream
putpmsg(2)
Sends a priority message downstream
poll(2)
Identifies files on which a user can send or receive messages, or on which certain events have occurred (historically, it was unnecessarily restricted to streams)
pipe(2)
Creates a bidirectional channel that provides a communication path between multiple processes
