STREAMS Programming Guide
Dismantling a Multiplexer
Streams connected to a multiplexing driver from above with open(2), can be dismantled by closing each stream with close(2). The mechanism for dismantling streams that have been linked below a multiplexing driver is less obvious, and is described in Disconnecting Lower Streams.
I_UNLINK ioctl(2) disconnects each multiplexer link below a multiplexing driver individually. This command has the form:
ioctl(fd, I_UNLINK, muxid);
where fd is a file descriptor associated with a stream connected to the multiplexing driver from above, and muxid is the identifier that was returned by I_LINK when a driver was linked below the multiplexer. Each lower driver may be disconnected individually in this way, or a special muxid value of MUXID_ALL can be used to disconnect all drivers from the multiplexer simultaneously.
In the multiplexing daemon program, the multiplexer is never explicitly dismantled. That is because all links associated with a multiplexing driver are automatically dismantled when the controlling stream associated with that multiplexer is closed. Because the controlling stream is open to a driver, only the final call of close for that stream will close it. In this case, the daemon is the only process that has opened the controlling stream, so the multiplexing configuration will be dismantled when the daemon exits.
For the automatic dismantling mechanism to work in the multilevel, multiplexed stream configuration, the controlling stream for each multiplexer at each level must be linked under the next higher-level multiplexer. In the example, the controlling stream for the IP driver was linked under the TP driver. This resulted in a single controlling stream for the full, multilevel configuration. Because the multiplexing program relied on closing the controlling stream to dismantle the multiplexed stream configuration instead of using explicit I_UNLINK calls, the muxid values returned by I_LINK could be ignored.
An important side effect of automatic dismantling on the close is that a process cannot build a multiplexing configuration with I_LINK and then exit. exit(2) closes all files associated with the process, including the controlling stream. To keep the configuration intact, the process must exist for the life of that multiplexer. That is the motivation for implementing the multiplexer as a daemon processs, see Multiplexing Driver Example.
If the process uses persistent links through I_PLINK ioctl(2), the multiplexer configuration remains intact after the process exits. These links are described in Persistent Links.
