When adding locks in a module, observe these constraints:
Avoid holding module private locks across calls to putnext(9F). The module might be re-entered by the same thread that called putnext(9F), causing the module to try to acquire a lock that it already holds. This can cause kernel panic.
Do not hold module private locks, acquired in put or service procedures, across the calls to qprocson(9F) or qprocsoff(9F). Doing this causes deadlock, since qprocson(9F) and qprocsoff(9F) wait until all threads leave the inner perimeter.
Similarly, do not hold locks, acquired in the timeout(9F) and bufcall(9F) callback procedures, across the calls to untimeout(9F) or unbufcall(9F). Doing this causes deadlock, because untimeout(9F)and unbufcall(9F) wait until an already executing callback has completed.
The first restriction deters using module private locks to preserve message ordering. The preferred mechanism is to use MT STREAMS perimeters to preserve message ordering.
