STREAMS Programming Guide
Packet Mode
In the STREAMS-based pseudo-terminal subsystem packet mode is used to inform the process on the master side when state changes have occurred in the pseudo-TTY. Packet mode is enabled by pushing the pckt module on the master side. Data written on the master side is processed normally. When data is written on the slave side, or when other messages are encountered by the pckt module, a header is added to the message so it can be subsequently retrieved by the master side with a getmsg operation.
pckt(7M) does the following:
