In addition to the standard PKCS #11 functions, two convenience functions are supplied with the Solaris cryptographic framework:
SUNW_C_GetMechSession() is a convenience function that initializes the Solaris cryptographic framework. The function then starts a session with the specified mechanism. SUNW_C_GetMechSession() uses the following syntax:
SUNW_C_GetMechSession(CK_MECHANISM_TYPE mech, C\ K_SESSION_HANDLE_PTR hSession)
The mech parameter is used to specify the mechanism to be used. hSession is a pointer to the session location.
Internally, SUNW_C_GetMechSession() calls C_Initialize() to initialize the cryptoki library. SUNW_C_GetMechSession() next calls C_GetSlotList() and C_GetMechanismInfo() to search through the available slots for a token with the specified mechanism. When the mechanism is found, SUNW_C_GetMechSession() calls C_OpenSession() to open a session.
The SUNW_C_GetMechSession() only needs to be called once. However, calling SUNW_C_GetMechSession() multiple times does not cause any problems.
SUNW_C_KeyToObject() creates a secret key object. The calling program must specify the mechanism to be used and raw key data. Internally, SUNW_C_KeyToObject() determines the type of key for the specified mechanism. A generic key object is created through C_CreateObject(). SUNW_C_KeyToObject() next calls C_GetSessionInfo() and C_GetMechanismInfo() to get the slot and mechanism. C_SetAttributeValue() then sets the attribute flag for the key object according to the type of mechanism.
