Oracle Solaris Security for Developers Guide
Miscellaneous GSSAPI Context Operations on the Client Side
As a sample program, gss-client performs some functions for demonstration purposes. The following source code is not essential for the basic task, but is provided to demonstrate these other operations:
The source code for these operations is shown in the following example.
Note –
The source code for this example is also available through the Sun download center. See http://www.sun.com/download/products.xml?id=41912db5.
Example 5–5 gss-client: call_server() Establish Context
/* Save and then restore the context */
     maj_stat = gss_export_sec_context(&min_stat,
                                           &context,
                                           &context_token);
     if (maj_stat != GSS_S_COMPLETE) {
             display_status("exporting context", maj_stat, min_stat);
             return -1;
     maj_stat = gss_import_sec_context(&min_stat,
                                           &context_token,
                                           &context);
        display_status("importing context", maj_stat, min_stat);
        return -1;
     (void) gss_release_buffer(&min_stat, &context_token);
     /* display the flags */
     display_ctx_flags(ret_flags);
     /* Get context information */
     maj_stat = gss_inquire_context(&min_stat, context,
                                    &src_name, &targ_name, &lifetime,
                                    &mechanism, &context_flags,
                                    &is_local,
                                    &is_open);
         display_status("inquiring context", maj_stat, min_stat);
         return -1;
     if (maj_stat == GSS_S_CONTEXT_EXPIRED) {
     printf(" context expired\n");
         display_status("Context is expired", maj_stat, min_stat);
         return -1;
