Oracle Solaris Modular Debugger Guide
Associating Panic Messages With Failures
The kernel memory allocator emits panic messages corresponding to the failure modes described earlier. For example, a system can panic with a message such as:
kernel memory allocator: buffer modified after being freed
modification occurred at offset 0x30
The allocator was able to detect this case because it tried to validate that the buffer in question was filled with 0xdeadbeef. At offset 0x30, this condition was not met. Since this condition indicates memory corruption, the allocator panicked the system.
Another example failure message is:
kernel memory allocator: redzone violation: write past end of buffer
The allocator was able to detect this case because it tried to validate that the redzone byte (0xbb) was in the location it determined from the redzone size encoding. It failed to find the signature byte in the correct location. Since this indicates memory corruption, the allocator panicked the system. Other allocator panic messages are discussed later.
