Multithreaded Programming Guide
Chapter 9 Programming Guidelines
This chapter provides some pointers on programming with threads. Most pointers apply to both Solaris and POSIX threads, but where utility differs, the behavior is noted. A change from single-threaded thinking to multithreaded thinking is emphasized in this chapter. The chapter discusses the following topics:
Rethinking Global Variables
Historically, most code has been designed for single-threaded programs. This code design is especially true for most of the library routines that are called from C programs. The following implicit assumptions were made for single-threaded code:
The following examples discuss some of the problems that arise in multithreaded programs because of these assumptions, and how you can deal with the problems.
Traditional, single-threaded C and UNIX have a convention for handling errors detected in system calls. System calls can return anything as a functional value. For example, write() returns the number of bytes that were transferred. However, the value -1 is reserved to indicate that something went wrong. So, when a system call returns -1, you know that the call failed.
Example 9–1 Global Variables and errno
extern int errno;
if (write(file_desc, buffer, size) == -1) {
    /* the system call failed */
    fprintf(stderr, “something went wrong, “
        “error code = %d\n”, errno);
    exit(1);
Rather than returning the actual error code, which could be confused with normal return values, the error code is placed into the global variable errno. When the system call fails, you can look in errno to find out what went wrong.
Now, consider what happens in a multithreaded environment when two threads fail at about the same time but with different errors. Both threads expect to find their error codes in errno, but one copy of errno cannot hold both values. This global variable approach does not work for multithreaded programs.
Threads solve this problem through a conceptually new storage class: thread-specific data. This storage is similar to global storage. Thread-specific data can be accessed from any procedure in which a thread might be running. However, thread-specific data is private to the thread. When two threads refer to the thread-specific data location of the same name, the threads are referring to two different areas of storage.
So, when using threads, each reference to errno is thread specific because each thread has a private copy of errno. A reference to errno as thread-specific is achieved in this implementation by making errno a macro that expands to a function call.
Providing for Static Local Variables
Example 9–2 shows a problem that is similar to the errno problem, but involving static storage instead of global storage. The function gethostbyname(3NSL) is called with the computer name as its argument. The return value is a pointer to a structure that contains the required information for contacting the computer through network communications.
Example 9–2 The gethostbyname() Problem
struct hostent *gethostbyname(char *name) {
    static struct hostent result;
        /* Lookup name in hosts database */
        /* Put answer in result */
    return(&result);
A pointer that is returned to a local variable is generally not a good idea. Using a pointer works in this example because the variable is static. However, when two threads call this variable at once with different computer names, the use of static storage conflicts.
Thread-specific data could be used as a replacement for static storage, as in the errno problem. But, this replacement involves dynamic allocation of storage and adds to the expense of the call.
A better way to handle this kind of problem is to make the caller of gethostbyname() supply the storage for the result of the call. An additional output argument to the routine enables the caller to supply the storage. The additional output argument requires a new interface to the gethostbyname() function.
This technique is used in threads to fix many of these problems. In most cases, the name of the new interface is the old name with “_r” appended, as in gethostbyname_r(3NSL).
Synchronizing Threads
The threads in an application must cooperate and synchronize when sharing the data and the resources of the process.
A problem arises when multiple threads call functions that manipulate an object. In a single-threaded world, synchronizing access to such objects is not a problem. However, as Example 9–3 illustrates, synchronization is a concern with multithreaded code. Note that the printf(3S) function is safe to call for a multithreaded program. This example illustrates what could happen if printf() were not safe.
Example 9–3 printf() Problem
/* thread 1: */
    printf("go to statement reached");
/* thread 2: */
    printf("hello world");
printed on display:
    go to hello
Single-Threaded Strategy
One strategy is to have a single, application-wide mutex lock acquired whenever any thread in the application is running and released before it must block. Because only one thread can be accessing shared data at any one time, each thread has a consistent view of memory.
Because this strategy is effectively single-threaded, very little is gained by this strategy.
Reentrant Function
A better approach is to take advantage of the principles of modularity and data encapsulation. A reentrant function behaves correctly if called simultaneously by several threads. To write a reentrant function is a matter of understanding just what behaves correctly means for this particular function.
Functions that are callable by several threads must be made reentrant. To make a function reentrant might require changes to the function interface or to the implementation.
Functions that access global state, like memory or files, have reentrance problems. These functions need to protect their use of global state with the appropriate synchronization mechanisms provided by threads.
The two basic strategies for making functions in modules reentrant are code locking and data locking.
Code Locking
Code locking is done at the function call level and guarantees that a function executes entirely under the protection of a lock. The assumption is for all access to data to be done through functions. Functions that share data should execute under the same lock.
Some parallel programming languages provide a construct called a monitor. The monitor implicitly does code locking for functions that are defined within the scope of the monitor. A monitor can also be implemented by a mutex lock.
Functions under the protection of the same mutex lock or within the same monitor are guaranteed to execute atomically with respect to other functions in the monitor.
Data Locking
Data locking guarantees that access to a collection of data is maintained consistently. For data locking, the concept of locking code is still there, but code locking is around references to shared (global) data, only. For mutual exclusion locking, only one thread can be in the critical section for each collection of data.
Alternatively, in a multiple reader, single writer protocol, several readers can be allowed for each collection of data or one writer. Multiple threads can execute in a single module when the threads operate on different data collections. In particular, the threads do not conflict on a single collection for the multiple readers, single writer protocol. So, data locking typically allows more concurrency than does code locking.
What strategy should you use when using locks, whether implemented with mutexes, condition variables, or semaphores, in a program? Should you try to achieve maximum parallelism by locking only when necessary and unlocking as soon as possible, called fine-grained locking? Or should you hold locks for long periods to minimize the overhead of taking and releasing locks, called coarse-grained locking?
The granularity of the lock depends on the amount of data protected by the lock. A very coarse-grained lock might be a single lock to protect all data. Dividing how the data is protected by the appropriate number of locks is very important. Locking that is too fine-grained can degrade performance. The overhead associated with acquiring and releasing locks can become significant when your application contains too many locks.
The common wisdom is to start with a coarse-grained approach, identify bottlenecks, and add finer-grained locking where necessary to alleviate the bottlenecks. This approach is reasonably sound advice, but use your own judgment about finding the balance between maximizing parallelism and minimizing lock overhead.
Invariants and Locks
For both code locking and data locking, invariants are important to control lock complexity. An invariant is a condition or relation that is always true.
The definition is modified somewhat for concurrent execution: an invariant is a condition or relation that is true when the associated lock is being set. Once the lock is set, the invariant can be false. However, the code that holds the lock must reestablish the invariant before releasing the lock.
An invariant can also be a condition or relation that is true when a lock is being set. Condition variables can be thought of as having an invariant that is the condition.
Example 9–4 Testing the Invariant With assert(3C)
    mutex_lock(&lock);
    while((condition)==FALSE)
        cond_wait(&cv,&lock);
    assert((condition)==TRUE);
    mutex_unlock(&lock);
The assert() statement is testing the invariant. The cond_wait() function does not preserve the invariant, which is why the invariant must be reevaluated when the thread returns.
Another example is a module that manages a doubly linked list of elements. For each item on the list, a good invariant is the forward pointer of the previous item on the list. The forward pointer should also point to the same element as the backward pointer of the forward item.
Assume that this module uses code-based locking and therefore is protected by a single global mutex lock. When an item is deleted or added, the mutex lock is acquired, the correct manipulation of the pointers is made, and the mutex lock is released. Obviously, at some point in the manipulation of the pointers the invariant is false, but the invariant is reestablished before the mutex lock is released.
Avoiding Deadlock
Deadlock is a permanent blocking of a set of threads that are competing for a set of resources. Just because some thread can make progress does not mean that a deadlock has not occurred somewhere else.
The most common error that causes deadlock is self deadlock or recursive deadlock. In a self deadlock or recursive deadlock, a thread tries to acquire a lock already held by the thread. Recursive deadlock is very easy to program by mistake.
For example, assume that a code monitor has every module function grab the mutex lock for the duration of the call. Then, any call between the functions within the module protected by the mutex lock immediately deadlocks. If a function calls code outside the module that circuitously calls back into any method protected by the same mutex lock, the function deadlocks too.
The solution for this kind of deadlock is to avoid calling functions outside the module that might depend on this module through some path. In particular, avoid calling functions that call back into the module without reestablishing invariants and do not drop all module locks before making the call. Of course, after the call completes and the locks are reacquired, the state must be verified to be sure the intended operation is still valid.
An example of another kind of deadlock is when two threads, thread 1 and thread 2, acquire a mutex lock, A and B, respectively. Suppose that thread 1 tries to acquire mutex lock B and thread 2 tries to acquire mutex lock A. Thread 1 cannot proceed while blocked waiting for mutex lock B. Thread 2 cannot proceed while blocked waiting for mutex lock A. Nothing can change. So, this condition is a permanent blocking of the threads, and a deadlock.
This kind of deadlock is avoided by establishing an order in which locks are acquired, a lock hierarchy. When all threads always acquire locks in the specified order, this deadlock is avoided.
Adherence to a strict order of lock acquisition is not always optimal. For instance, thread 2 has many assumptions about the state of the module while holding mutex lock B. Giving up mutex lock B to acquire mutex lock A and then reacquiring mutex lock B in that order causes the thread to discard its assumptions. The state of the module must be reevaluated.
The blocking synchronization primitives usually have variants that attempt to get a lock and fail if the variants cannot get the lock. An example is pthread_mutex_trylock() . This behavior of primitive variants allows threads to violate the lock hierarchy when no contention occurs. When contention occurs, the held locks must usually be discarded and the locks reacquired in order.
Deadlocks Related to Scheduling
Because the order in which locks are acquired is not guaranteed, a problem can occur where a particular thread never acquires a lock.
This problem usually happens when the thread holding the lock releases the lock, lets a small amount of time pass, and then reacquires the lock. Because the lock was released, the appearance is that the other thread should acquire the lock. But, nothing blocks the thread holding the lock. Consequently, that thread continues to run from the time the thread releases the lock until the time the lock is reacquired. Thus, no other thread is run.
You can usually solve this type of problem by calling sched_yield()(3C) just before the call to reacquire the lock. The sched_yield() function allows other threads to run and to acquire the lock.
Because the time-slice requirements of applications are so variable, the system does not impose any requirements. Use calls to sched_yield() to make threads share time as you require.
Locking Guidelines
Follow these simple guidelines for locking.
Finding Deadlocks
The Sun Studio Thread Analyzer is a tool that you can use to find deadlocks in your program. The Thread Analyzer can detect potential deadlocks as well as actual deadlocks. A potential deadlock does not necessarily occur in a given run, but can occur in any execution of the program depending on the scheduling of threads and the timing of lock requests by the threads. An actual deadlock is one that occurs during the execution of a program, causing the threads involved to hang, but may or may not cause the whole process to hang.
See the Sun Studio 12: Thread Analyzer User’s Guide.
Some Basic Guidelines for Threaded Code
Creating and Using Threads
The threads packages cache the threads data structure and stacks so that the repetitive creation of threads can be reasonably inexpensive. However, creating and destroying threads as the threads are required is usually more expensive than managing a pool of threads that wait for independent work. A good example is an RPC server that creates a thread for each request and destroys the thread when the reply is delivered.
Thread creation has less overhead than the overhead of process creation. However, thread creation is not efficient when compared to the cost of creating a few instructions. Create threads for processing that lasts at least a couple of thousand machine instructions.
Working With Multiprocessors
Multithreading enables you to take advantage of multiprocessors, including multicore and multithreaded processors, primarily through parallelism and scalability. Programmers should be aware of the differences between the memory models of a multiprocessor and a uniprocessor.
Note –
In this manual, whenever multiprocessors are discussed, the context applies also to multicore and multithreaded processors unless noted otherwise.
Memory consistency is directly interrelated to the processor that interrogates memory. For uniprocessors, memory is obviously consistent because only one processor is viewing memory.
To improve multiprocessor performance, memory consistency is relaxed. You cannot always assume that changes made to memory by one processor are immediately reflected in the other processors' views of that memory.
You can avoid this complexity by using synchronization variables when you use shared or global variables.
Memory barrier synchronization is sometimes an efficient way to control parallelism on multiprocessors.
Another multiprocessor issue is efficient synchronization when threads must wait until all threads have reached a common point in their execution.
Note –
The issues discussed here are not important when the threads synchronization primitives are always used to access shared memory locations. See Chapter 4, Programming with Synchronization Objects.
Underlying Architecture
Threads synchronize access to shared storage locations by using the threads synchronization routines. With threads synchronization, running a program on a shared-memory multiprocessor has the identical effect of running the program on a uniprocessor.
However, in many situations a programmer might be tempted to take advantage of the multiprocessor and use “tricks” to avoid the synchronization routines. As Example 9–5 and Example 9–6 show, such tricks can be dangerous.
An understanding of the memory models supported by common multiprocessor architectures helps to understand the dangers.
The major multiprocessor components are:
In the simple traditional model, the multiprocessor behaves as if the processors are connected directly to memory: when one processor stores into a location and another processor immediately loads from the same location, the second processor loads what was stored by the first.
Caches can be used to speed the average memory access. The desired semantics can be achieved when the caches are kept consistent with the other caches.
A problem with this simple approach is that the processor must often be delayed to make certain that the desired semantics are achieved. Many modern multiprocessors use various techniques to prevent such delays, which unfortunately change the semantics of the memory model.
Two of these techniques and their effects are explained in the next two examples.
Shared-Memory Multiprocessors
Consider the purported solution to the producer and consumer problem that is shown in Example 9–5.
Although this program works on current SPARC-based multiprocessors, the program assumes that all multiprocessors have strongly ordered memory. This program is therefore not portable.
Example 9–5 Producer and Consumer Problem: Shared Memory Multiprocessors
char buffer[BSIZE];
unsigned int in = 0;
unsigned int out = 0;
/* Thread 1 (producer) */
/* Thread 2 (consumer) */
void
producer(char item) {
     do
        ;/* nothing */
     while
         ((in - out) == BSIZE);
     buffer[in%BSIZE] = item;
     in++;
char
consumer(void) {
     char item;
     do
        ;/* nothing */
     while
         ((in - out) == 0);
     item = buffer[out%BSIZE];
     out++;
When this program has exactly one producer and exactly one consumer and is run on a shared-memory multiprocessor, the program appears to be correct. The difference between in and out is the number of items in the buffer.
The producer waits, by repeatedly computing this difference, until room is available in the buffer for a new item. The consumer waits until an item is present in the buffer.
Strongly-ordered memory makes a modification to memory on one processor immediately available to the other processors. For strongly ordered memory, the solution is correct even taking into account that in and out will eventually overflow. The overflow occurs as long as BSIZE is less than the largest integer that can be represented in a word.
Shared-memory multiprocessors do not necessarily have strongly ordered memory. A change to memory by one processor is not necessarily available immediately to the other processors. See what happens when two changes to different memory locations are made by one processor. The other processors do not necessarily detect the changes in the order in which the changes were made because memory modifications do not happen immediately.
First the changes are stored in store buffers that are not visible to the cache.
The processor checks these store buffers to ensure that a program has a consistent view. But, because store buffers are not visible to other processors, a write by one processor does not become visible until the processor writes to cache.
The synchronization primitives use special instructions that flush the store buffers to cache. See Chapter 4, Programming with Synchronization Objects. So, using locks around your shared data ensures memory consistency.
When memory ordering is very relaxed, Example 9–5 has a problem. The consumer might see that in has been incremented by the producer before the consumer sees the change to the corresponding buffer slot.
This memory ordering is called weak ordering because stores made by one processor can appear to happen out of order by another processor. Memory, however, is always consistent from the same processor. To fix this inconsistency, the code should use mutexes to flush the cache.
Because the trend is toward relaxing memory order, programmers must be careful to use locks around all global or shared data.
As demonstrated by Example 9–5 and Example 9–6, locking is essential.
Peterson's Algorithm
The code in Example 9–6 is an implementation of Peterson's Algorithm, which handles mutual exclusion between two threads. This code tries to guarantee that only one thread is in the critical section. When a thread calls mut_excl(), the thread enters the critical section sometime “soon.”
An assumption here is that a thread exits fairly quickly after entering the critical section.
Example 9–6 Mutual Exclusion for Two Threads
void mut_excl(int me /* 0 or 1 */) {
    static int loser;
    static int interested[2] = {0, 0};
    int other; /* local variable */
    other = 1 - me;
    interested[me] = 1;
    loser = me;
    while (loser == me && interested[other])
    /* critical section */
    interested[me] = 0;
This algorithm works some of the time when the multiprocessor has strongly ordered memory.
Some multiprocessors, including some SPARC-based multiprocessors, have store buffers. When a thread issues a store instruction, the data is put into a store buffer. The buffer contents are eventually sent to the cache, but not necessarily right away. The caches on each of the processors maintain a consistent view of memory, but modified data does not reach the cache right away.
When multiple memory locations are stored into, the changes reach the cache and memory in the correct order, but possibly after a delay. SPARC-based multiprocessors with this property are said to have total store order (TSO).
Suppose you have a situation where one processor stores into location A and loads from location B. Another processor stores into location B and loads from location A. Either the first processor fetches the newly-modified value from location B, or the second processor fetches the newly-modified value from location A, or both. However, the case in which both processors load the old values cannot happen.
Moreover, with the delays caused by load and store buffers, the “impossible case” can happen.
What could happen with Peterson's algorithm is that two threads running on separate processors both enter the critical section. Each thread stores into its own slot of the particular array and then loads from the other slot. Both threads read the old values (0), each thread assumes that the other party is not present, and both enter the critical section. This kind of problem might not be detected when you test a program, but only occurs much later.
To avoid this problem use the threads synchronization primitives, whose implementations issue special instructions, to force the writing of the store buffers to the cache. See Chapter 4, Programming with Synchronization Objects.
Parallelizing a Loop on a Shared-Memory Parallel Computer
In many applications, and especially numerical applications, while part of the algorithm can be parallelized, other parts are inherently sequential, as shown in the following table. The algorithm can use barrier synchronization to coordinate the parallel and sequential portions.
Table 9–1 Multithreaded Cooperation Through Barrier Synchronization
Sequential Execution
Parallel Execution
Thread 1
Thread 2 through Thread n
while(many_iterations) {
    sequential_computation
    --- Barrier ---
    parallel_computation
    --- Barrier ---
For example, you might produce a set of matrixes with a strictly linear computation, and perform operations on the matrixes that use a parallel algorithm. You then use the results of these operations to produce another set of matrixes, operate on these matrixes in parallel, and so on.
The nature of the parallel algorithms for such a computation is that little synchronization is required during the computation. But, synchronization of all the threads is required to ensure that the sequential computation is finished before the parallel computation begins.
The barrier forces all the threads that are doing the parallel computation to wait until all involved threads have reached the barrier. When the threads have reached the barrier, the threads are released and begin computing together.
Examples of Threads Programs
This guide has covered a wide variety of important threads programming issues. Appendix A, Extended Example: A Thread Pool Implementation provides a pthreads program example that uses many of the features and styles that have been discussed.
Further Reading
For more in-depth information about multithreading, see Programming with Threads by Steve Kleiman, Devang Shah, and Bart Smaalders (Prentice-Hall, published in 1995). Note that although the book is not current with changes to the Solaris OS, much of the conceptual information is still valid.
