Name | Synopsis | Description | Options | Environment Variables | Files | Attributes | See Also | Bugs | AUTHORS
/usr/bin/kdestroy [-q] [-c cache_name]
The kdestroy utility destroys the user's active Kerberos authorization tickets by writing zeros to the specified credentials cache that contains them. If the credentials cache is not specified, the default credentials cache is destroyed. If the credentials cache does not exist, kdestroy displays a message to that effect.
After overwriting the cache, kdestroy removes the cache from the system. The utility displays a message indicating the success or failure of the operation. If kdestroy is unable to destroy the cache, it will warn you by making your terminal beep.
If desired, you can place the kdestroy command in your .logout file so that your tickets are destroyed automatically when you logout.
The following options are supported:
Uses cache_name as the credentials (ticket) cache name and location. If this option is not used, the default cache name and location are used.
Runs quietly. Your terminal will not beep when kdestroy fails to destroy the tickets.
kdestroy uses the following environment variable:
Location of the credentials (ticket) cache. See krb5envvar(5) for syntax and details.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWkrbu |
Interface Stability |
Evolving |
Command arguments |
Evolving |
Command output |
Unstable |
Only the tickets in the specified credentials cache are destroyed. Separate ticket caches are used to hold root instance and password changing tickets. These files should probably be destroyed too, or all of a user's tickets should be kept in a single credential cache.
Steve Miller, MIT Project Athena/Digital Equipment Corporation; Clifford Neuman, MIT Project Athena Bill Sommerfeld, MIT Project Athena
