Name | Synopsis | Description | Options | Exit Status | Files | Attributes | See Also | Notes
/usr/sbin/atohexlabel [human-readable-sensitivity-label]
/usr/sbin/atohexlabel -c [human-readable-clearance]
atohexlabel converts a human readable label into an internal text representation that is safe for storing in a public object. If no option is supplied, the label is assumed to be a sensitivity label.
Internal conversions can later be parsed to their same value. This internal form is often hexadecimal. The converted label is written to the standard output file. If no human readable label is specified, the label is read from the standard input file. The expected use of this command is emergency repair of labels that are stored in internal databases.
The following exit values are returned:
On success.
On failure, and writes diagnostics to the standard error file.
The label encodings file contains the classification names, words, constraints, and values for the defined labels of this system.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWtsu |
Interface Stability |
See below. |
The command output is Committed for systems with the same label_encodings file. The command invocation is Committed for systems that implement the DIA MAC policy.
The functionality described on this manual page is available only if the system is configured with Trusted Extensions.
This file is part of the Defense Intelligence Agency (DIA) Mandatory Access Control (MAC) policy. This file might not be applicable to other MAC policies that might be developed for future releases of Solaris Trusted Extensions software.
