Name | Synopsis | Description | Return Values | Errors | Attributes | See Also
cc [ flag ... ] file ... -ldlpi [ library ... ] #include <libdlpi.h> int dlpi_unbind(dlpi_handle_t dh);
The dlpi_unbind() function unbinds to bind the DLPI handle dh from the bound SAP. The handle must be in the DL_IDLE DLPI state and upon success, the handle transitions to the DL_UNBOUND state.
Upon success, the caller will no longer be able to send or receive data using the DLPI link associated with dh.
Upon success, DLPI_SUCCESS is returned. If DL_SYSERR is returned, errno contains the specific UNIX system error value. Otherwise, a DLPI error value defined in <sys/dlpi.h> or an error value DLPI_ETIMEDOUT will be returned.
Bad DLPI message
Invalid DLPI handle
DLPI operation timed out
See attributes(5) for description of the following attributes:
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Interface Stability |
Committed |
MT-Level |
Safe |
