Name | Synopsis | Parameters | Description | Return Values | Errors | Attributes | See Also
cc [ flag... ] file... -ldevinfo [ library... ] #include <libdevinfo.h> di_minor_t di_minor_next(di_node_t node, di_minor_t minor);
Handle to the current minor node or DI_MINOR_NIL.
Device node with which the minor node is associated.
The di_minor_next() function returns a handle to the next minor node for the device node node. If minor is DI_MINOR_NIL, a handle to the first minor node is returned.
Upon successful completion, a handle to the next minor node is returned. Otherwise, DI_MINOR_NIL is returned and errno is set to indicate the error.
The di_minor_next() function will fail if:
Invalid argument.
Minor node information is not available in snapshot.
End of minor node list.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Interface Stability |
Evolving |
MT-Level |
Safe |
