Name | Synopsis | Description | Return Values | Errors | Examples | Attributes | See Also
c99 [ flag... ] file... -lm [ library... ] #include <fenv.h> int fetestexcept(int excepts);
The fetestexcept() function determines which of a specified subset of the floating-point exception flags are currently set. The excepts argument specifies the floating-point status flags to be queried.
The fetestexcept() function returns the value of the bitwise-inclusive OR of the floating-point exception macros corresponding to the currently set floating-point exceptions included in excepts.
No errors are defined.
The following example calls function f( ) if an invalid exception is set, and then function g( ) if an overflow exception is set:
#include <fenv.h> /* ... */ { # pragma STDC FENV_ACCESS ON int set_excepts; feclearexcept(FE_INVALID | FE_OVERFLOW); // maybe raise exceptions set_excepts = fetestexcept(FE_INVALID | FE_OVERFLOW); if (set_excepts & FE_INVALID) f(); if (set_excepts & FE_OVERFLOW) g(); /* ... */ }
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Interface Stability |
Standard |
MT-Level |
MT-Safe |
