Name | Synopsis | Description | Return Values | Errors | Attributes | See Also
cc [ flag… ] file… -llgrp [ library… ] #include <sys/lgrp_user.h> int lgrp_fini(lgrp_cookie_t cookie);
The lgrp_fini() function takes a cookie, frees the snapshot of the lgroup hierarchy created by lgrp_init(3LGRP), and cleans up anything else set up by lgrp_init(). After this function is called, any memory allocated and returned by the lgroup interface might no longer be valid and should not be used.
Upon successful completion, 0 is returned. Otherwise, -1 is returned and errno is set to indicate the error.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Interface Stability |
Evolving |
MT-Level |
MT-Safe |
