Name | Synopsis | Description | CONFIGURATION | Files | Attributes | See Also | Diagnostics
sata@unit-address
The marvell88sx driver is a SATA framework-compliant HBA driver that supports the Marvell 88SX5081, 88SX5080, 88SX5040, 88SX5041, 88SX6081, and 88SX6041 controllers.
The 88SX5081, 88SX5080, 88SX5040 and 88SX5041 Marvell controllers are fully compliant with the Serial ATA 1.0 specification and support the SATA device hot-swap compliant 1.5 Gbps speed feature.
The 88SX6081 and 88SX6041 Marvell controllers are fully-compliant with the SATA II Phase 1.0 specification (the extension to the SATA 1.0 specification) and support SATA II native command queuing and backwards compatibility with SATA I 1.5 Gpbs speed and devices. In addition, the 88SX6081 device supports the SATA II Phase 1.0 specification features, including SATA II 3.0 Gbps speed, SATA II Port Multiplier functionality and SATA II Port Selector.
Currently the driver does not support port multiplier or port selector functionality.
There are no tunable parameters in the marvell88sx.conf file.
32–bit ELF 86 kernel module.
64–bit ELF kernel module.
Driver configuration file.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Architecture |
x86 |
Availability |
driver/storage/marvell88sx |
In addition to being logged, the following messages may appear on the system console:
marvell88sx<n>:PCI error address 0x<high addr>:<low addr> PCI command 0x<command>DAC [true|false] attribute 0x<attribute><pci error type>. |
The nth instance of a marvell88sx reports a PCI bus status message. (A hardware issue needs attention). The PCI bus address, PCI command (whether or not it was a dual address command), the PCI-X attribute bit, and the error type are displayed.
marvell88sx<n>: port <port #>: error in PIO command 0<cmd>x: status 0x<status>. |
The port number on the nth marvell88sx controller received an error while performing a programmed I/O command <cmd> with status <status>.
marvell88sx<n>: error on port<port#>: One or more of the following: |
ATA UDMA data parity error ATA UDMA PRD parity error device error device disconnected device connected SError interrupt reserved bit 6 EDMA self disabled BIST FIS or asynchronous notification command request queue parity error command response queue parity error internal memory parity error I/O ready time-out link control receive error - crc link control receive error - fifo link control receive error - reset link control receive error - state link data receive error - crc link data receive error - fifo link data receive error - reset link data receive error - state link control transmit error - crc link control transmit error - fifo link control transmit error - reset link control transmit error - DMAT link control transmit error - collision link data transmit error -crc link data transmit error - fifo link data transmit error - reset link data transmit error - DMAT link data transmit error - collision transport protocol error
The port number on the nth marvell88sx controller received one or more error conditions as listed.
marvell88sx<n>: device on port <port #> still busy. |
The port number on the nth marvell88sx remains busy. (Indicates a hardware problem). Check the disk and the controller.
marvell88sx<n>: pci_config_setup failed. |
Could not access PCI configuration space for the nth marvell88sx controller.
marvell88sx<n>:failed to get device id. |
The device-id property for the nth marvell88sx controller cannot be read.
marvell88sx<n>: Unrecognized device - device id 0x<device id> assuming <n> ports. |
The device id associated with the nth marvell88sx controller is not supported and the number of ports could not be determined. n ports are being assumed.
marvell88sx<n>:Unrecognized device - device idOx<device id>. |
The device id associated with the nth marvell88sx controller is not supported.
marvell88sx<n>: Could not attach. Could not allocate softstate. |
A call to ddi_soft_state_zalloc() failed for the nth marvell88sx controller. The system may be low on resources. The driver failed to attach.
marvell88sx<n>: Could not attach, unknown device model. |
The nth marvell88sx controller is unsupported hardware. The driver failed to attach.
marvell88sx<n>: Could not attach, unsupported chip step- ping or unable to get the chip stepping. |
The nth marvell88sx controller is not supported due to a known bad chip stepping or a stepping of an unknown model.
marvell88sx<n>: ddi_intr_get_supported_types failed. |
marvell88sx<n>: power management component not created. |
Power management is not supported.
mavell88sx<n>: unable to attach to sata framework. |
marvell88sx<n>: unable to detach from sata framework. |
The driver failed to detach.
marvell88sx<n>: Could not attach, failed interrupt registration. |
marvell88sx<n>: Cannot get number interrupts, rc |
The number of interrupts for the nth marvell88sx device could not be determined.
marvell88sx<n>: 0 is not a valid number of interrupts. |
The number of interrupts for the nth marvell88sx device was returned as 0.
marvell88sx<n>: Failed to get the number of available interrupts. |
The number of available interrupts for the nth marvell88sx controller could not be determined.
marvell88sx<n>: Number of available interrupts is 0. |
No interrupts were available for the nth marvell88sx device.
marvell88sx<n>: could not allocate interrupts. |
The interrupts for the nth marvell88sx device could not be allocated.
marvell88sx<n>: could not get interrupt priority. |
The interrupt priority for the nth marvell88sx device could not be determined.
marvell88sx<n>: Could not add interrupt handler. |
An interrupt service routine could not be added to the system for the nth marvell88sx device.
marvell88sx<n>:polled read/write request never completed- port <num>. |
A polled read or write did not complete in a reasonable amount of time. If this problem persists, there may be a hardware problem with (a) the controller, (b) the controller port, (c) the disk attached to controller port or (d) the cabling.
marvell88sx<n>: EDMA never disabled. |
Could not disable EDMA. (Indicates a hardware problem).
marvell88sx<n>: Could not attach. |
The nth marvell8ssx device could not attach. This message is usually preceded by another warning indicating why the attach failed.
SunOS 5.10 Last Revised 5 Apr 2010Name | Synopsis | Description | CONFIGURATION | Files | Attributes | See Also | Diagnostics
