Name | Synopsis | Interface Level | Parameters | Description | Context | See Also
#include <sys/scsi/scsi.h> void scsi_sync_pkt(struct scsi_pkt *pktp);
Solaris DDI specific (Solaris DDI).
Pointer to a scsi_pkt(9S) structure.
The scsi_sync_pkt() function is used to selectively synchronize a CPU's or device's view of the data associated with the SCSI packet that has been mapped for I/O. This may involve operations such as flushes of CPU or I/O caches, as well as other more complex operations such as stalling until hardware write buffers have drained.
This function need only be called under certain circumstances. When a SCSI packet is mapped for I/O using scsi_init_pkt(9F) and destroyed using scsi_destroy_pkt(9F), then an implicit scsi_sync_pkt() will be performed. However, if the memory object has been modified by either the device or a CPU after the mapping by scsi_init_pkt(9F), then a call to scsi_sync_pkt() is required.
If the same scsi_pkt is reused for a data transfer from memory to a device, then scsi_sync_pkt() must be called before calling scsi_transport(9F). If the same packet is reused for a data transfer from a device to memory scsi_sync_pkt() must be called after the completion of the packet but before accessing the data in memory.
The scsi_sync_pkt() function may be called from user, interrupt, or kernel context.
tran_sync_pkt(9E), ddi_dma_sync(9F), scsi_destroy_pkt(9F), scsi_init_pkt(9F), scsi_transport(9F), scsi_pkt(9S)
