Solaris Smartcard Administration Guide
ProcedureTo Remove a Card Reader (Command Line)
  1. Verify that the ocfserv daemon is enabled.
    The following command provides the status of the service.
    % svcs network/rpc/ocfserv
    Note –
    Before you make any changes to Smartcard, you must make sure that the ocfserv daemon is enabled.
  2. (Optional) If necessary, as root, enable the ocfserv daemon.
    # svcadm enable network/rpc/ocfserv
  3. Remove the card reader.
    # smartcard -c admin -t terminal -r user_friendly_reader_name -x delete
  4. (Optional) Disconnect the external card reader from the port.
  5. Restart ocfserv.
    # svcadm restart network/rpc/ocfserv
    The ocfserv process is restarted the next time you use the Smartcard Console or execute the smartcard command.
