Solaris Smartcard Administration Guide
ProcedureTo Set Card Removal Options (Console)
  1. Verify that the ocfserv daemon is enabled.
    The following command provides the status of the service.
    % svcs network/rpc/ocfserv
    Note –
    Before you make any changes to Smartcard, you must make sure that the ocfserv daemon is enabled.
  2. (Optional) If necessary, as root, enable the ocfserv daemon.
    # svcadm enable network/rpc/ocfserv
  3. Select OCF Clients in the Navigation pane.
  4. Select the Desktop icon in the Console pane.
  5. Choose Properties in the Action menu.
    The Configure Clients dialog box is displayed.
  6. Select the Options tab in the dialog box.
  7. Click the checkboxes to toggle between on or off.
    • Ignore Card Removal – If checked, nothing happens when a smart card is removed from the reader.
    • Reauthenticate After Card Removal – If checked, a user is logged out when a card is removed. If Reauthenticate is not checked, the Card Removal Logout Wait setting—in the Timeouts tab—determines what happens.
  8. Click the Apply or OK button.
  9. Exit CDE to activate the change.
