Solaris Smartcard Administration Guide
ProcedureTo Start the Smartcard Console From the Command Line
  1. Log in as root or su to root.
    Note –
    If you log in as a regular user, you can run Smartcard, but you can only perform two tasks: Load Applets and Configure Applets.
  2. Verify that the ocfserv daemon is enabled.
    The following command provides the status of the service.
    # svcs network/rpc/ocfserv
    Note –
    Before you make any changes to Smartcard, you must make sure that the ocfserv daemon is enabled.
  3. (Optional) If necessary, enable the ocfserv daemon.
    # svcadm enable network/rpc/ocfserv
  4. Start the Smartcard Console:
    # /usr/dt/bin/sdtsmartcardadmin &
    Note –
    Before you su to root, you might need to disable X server access control, because root is not granted access by default. Disable X server access control by running /usr/openwin/bin/xhost +hostname where hostname is the local host. After starting the Smartcard Console, run xhost -hostname to enable access control again.
