Solaris Smartcard Administration Guide
ProcedureTo Verify a PIN for a Smart Card
Use this procedure to verify the PIN for a smart card.
  1. Verify that the ocfserv daemon is enabled.
    The following command provides the status of the service.
    % svcs network/rpc/ocfserv
    Note –
    Before you make any changes to Smartcard, you must make sure that the ocfserv daemon is enabled.
  2. (Optional) If necessary, as root, enable the ocfserv daemon.
    # svcadm enable network/rpc/ocfserv
  3. Insert the smart card into the card reader.
  4. As root, type the following to verify the PIN for the smart card.
    # smartcard -c init -A A000000062030400 -P 'PIN_number'
    PIN_number represents the PIN set for the card and A000000062030400 is the applet ID for the SolarisAuthApplet.
    If the PIN is invalid, an Invalid PIN message is displayed. A valid PIN results in no output.
