Solaris Smartcard Administration Guide
ProcedureTo Disable Smartcard
You might need to disable Smartcard on a system in the following instances:
Do the following to disable Solaris Smartcard.
  1. Verify that the ocfserv daemon is enabled.
    The following command provides the status of the service.
    % svcs network/rpc/ocfserv
    Note –
    Before you make any changes to Smartcard, you must make sure that the ocfserv daemon is enabled.
  2. (Optional) If necessary, as root, enable the ocfserv daemon.
    # svcadm enable network/rpc/ocfserv
  3. Disable smart-card operations.
    # smartcard -c disable
