Solaris Smartcard Administration Guide
ProcedureTo Enable Debugging (Command Line)
Use the following procedure to enable smart-card debugging.
  1. Verify that the ocfserv daemon is enabled.
    The following command provides the status of the service.
    % svcs network/rpc/ocfserv
    Note –
    Before you make any changes to Smartcard, you must make sure that the ocfserv daemon is enabled.
  2. (Optional) If necessary, as root, enable the ocfserv daemon.
    # svcadm enable network/rpc/ocfserv
  3. Enable smart card debugging by setting debugging=1.
    # smartcard -c admin -x modify debugging=1
    In the following example, the location of the ocfserv debugging file is changed. The location is changed by using the -x modify debugging.filename option and by specifying a fully qualified file name for the debugging file.
    # smartcard -c admin -x modify debugging.filename=/var/tmp/sc.debug
