Become superuser or assume an equivalent role.
Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
View the status of a ttymon port monitor.
# sacadm -l -p mbmon |
Specifies the list port monitor status flag.
Specifies the pmtag mbmon as the port monitor tag.
This example shows how to view a port monitor named, mbmon.
# sacadm -l -p mbmon PMTAG PMTYPE FLGS RCNT STATUS COMMAND mbmon ttymon - 0 STARTING /usr/lib/saf/ttymon #TTY Ports a & b |
Identifies the port monitor name, mbmon.
Identifies the port monitor type, ttymon.
Indicates whether the following flags are set:
Do not enable the new port monitor.
Do not start the new port monitor.
No flags are set.
Indicates the return count value. A return count of 0 indicates that the port monitor is not to be restarted if it fails.
Indicates the current status of the port monitor.
Identifies the command used to start the port monitor.
Identifies any comment used to describe the port monitor.
