System Administration Guide: Advanced Administration
ProcedureHow to Remove a ttymon Port Monitor
Removing a port monitor deletes all the configuration files associated with it.
Note –
Port monitor configuration files cannot be updated or changed by using the sacadm command. To reconfigure a port monitor, remove it and then add a new one.
  1. Become superuser or assume an equivalent role.
    Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
  2. Remove a ttymon port monitor.
    # sacadm -r -p mbmon
    -r
    Specifies the remove port monitor status flag.
    -p
    Specifies the pmtag mbmon as the port monitor tag.
