System Administration Guide: Advanced Administration
Administering ttymon Port Monitors
Console administration for ttymon is now managed by SMF. Use the svccfg command to set ttymon system console properties. Continue to use the SAF command, sacadm, to add, list, remove, kill, start, enable, disable, enable, and remove ttymon port monitors.
ProcedureHow to Set the ttymon Console Terminal Type
This procedure shows how to change the console terminal type by using the svccfg command.
  1. Become superuser or assume an equivalent role.
    Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
  2. Run the svccfg command to set the property for the service instance that you want to change.
    # svccfg -s console-login setprop ttymon/terminal_type = "xterm"
    where xterm is an example of a terminal type that you might want to use.
  3. (Optional) Restart the service instance.
    # svcadm restart svc:/system/console-login:default
    Caution – Caution –
    If you choose to restart the service instance immediately, you are logged out of the console. If you do not restart the service instance immediately, the property changes apply at the next login prompt on the console.
ProcedureHow to Set the Baud Rate Speed on the ttymon Console Terminal
This procedure shows how to set the baud rate speed on the ttymon console terminal. Support for console speeds on x86 based systems are dependent on the specific platform.
The following are supported console speeds for SPARC based systems:
  2. Use the eeprom command to set a baud rate speed that is appropriate for your system type.
    # eeprom ttya-mode=baud-rate,8,n,1,-
    For example, to change the baud rate on an x86 based system's console to 38400, type:
    # eeprom ttya-mode=38400,8,n,1,-
  3. Change the console line in the /etc/ttydefs file as follows:
    console baud-rate hupcl opost onlcr:baud-rate::console
  4. Make the following additional changes for your system type.
    Note that these changes are platform-dependent.
    • On SPARC based systems: Change the baud rate speed in the /kernel/drv/options.conf file.
      Use the following command to change the baud rate to 9600:
      # 9600             :bd:
      ttymodes="2502:1805:bd:8a3b:3:1c:7f:15:4:0:0:0:11:13:1a:19:12:f:17:16";
      Use the following command to change the baud rate speed to 19200.
      # 19200            :be:
      ttymodes="2502:1805:be:8a3b:3:1c:7f:15:4:0:0:0:11:13:1a:19:12:f:17:16";
      Use the following command to change the baud rate speed to 38400:
      # 38400            :bf:
      ttymodes="2502:1805:bf:8a3b:3:1c:7f:15:4:0:0:0:11:13:1a:19:12:f:17:16";
    • On x86 based systems: Change the console speed if the BIOS serial redirection is enabled. The method that you use to change the console speed is platform-dependent.
ProcedureHow to Add a ttymon Port Monitor
  2. Add a ttymon port monitor.
    # sacadm -a -p mbmon -t ttymon -c /usr/lib/saf/ttymon -v `ttyadm
    -V` -y "TTY Ports a & b"
    -a
    Specifies the add port monitor option.
    -p
    Specifies the pmtag mbmon as the port monitor tag.
    -t
    Specifies the port monitor type as ttymon.
    -c
    Defines the command string used to start the port monitor.
    -v
    Specifies the version number of the port monitor.
    -y
    Defines a comment to describe this instance of the port monitor.
ProcedureHow to View ttymon Port Monitor Status
  2. View the status of a ttymon port monitor.
    # sacadm -l -p mbmon
    -l
    Specifies the list port monitor status flag.
    -p
Example 3–1 Viewing ttymon Port Monitor Status
This example shows how to view a port monitor named, mbmon.
PMTAG  PMTYPE  FLGS RCNT STATUS    COMMAND
mbmon  ttymon  -    0    STARTING  /usr/lib/saf/ttymon #TTY Ports a & b
PMTAG
Identifies the port monitor name, mbmon.
PMTYPE
Identifies the port monitor type, ttymon.
FLGS
Indicates whether the following flags are set:
d
Do not enable the new port monitor.
x
Do not start the new port monitor.
dash (-)
No flags are set.
RCNT
Indicates the return count value. A return count of 0 indicates that the port monitor is not to be restarted if it fails.
STATUS
Indicates the current status of the port monitor.
COMMAND
Identifies the command used to start the port monitor.
#TTY Ports a & b
Identifies any comment used to describe the port monitor.
ProcedureHow to Stop a ttymon Port Monitor
  2. Stop a ttymon port monitor.
    # sacadm -k -p mbmon
    -k
    Specifies the kill port monitor status flag.
    -p
ProcedureHow to Start a ttymon Port Monitor
  2. Start a killed ttymon port monitor.
    # sacadm -s -p mbmon
    -s
    Specifies the start port monitor status flag.
    -p
ProcedureHow to Disable a ttymon Port Monitor
Disabling a port monitor prevents new services from starting, without affecting existing services.
  2. Disable a ttymon port monitor.
    # sacadm -d -p mbmon
    -d
    Specifies the disable port monitor status flag.
    -p
ProcedureHow to Enable a ttymon Port Monitor
Enabling a ttymon port monitor allows it to service new requests.
  2. Enable a ttymon port monitor.
    # sacadm -e -p mbmon
    -e
    Specifies the enable port monitor status flag.
    -p
ProcedureHow to Remove a ttymon Port Monitor
Removing a port monitor deletes all the configuration files associated with it.
Note –
Port monitor configuration files cannot be updated or changed by using the sacadm command. To reconfigure a port monitor, remove it and then add a new one.
  2. Remove a ttymon port monitor.
    # sacadm -r -p mbmon
    -r
    Specifies the remove port monitor status flag.
    -p
