System Administration Guide: Advanced Administration
Port Monitor States
The sacadm command controls the states of the ttymon and listen port monitors. The following table describes the possible port monitor states.
State
Description
Started
Default state – When the port monitor is added, it is automatically started.
Enabled
Default state – When the port monitor is added, it is automatically ready to accept requests for service.
Stopped
Default state – When the port monitor is removed, it is automatically stopped.
Disabled
Default state – When the port monitor is removed, it automatically continues existing services and refuses to add new services.
Starting
Intermediate state – The port monitor is in the process of starting.
Stopping
Intermediate state – The port monitor has been manually terminated, but it has not completed its shutdown procedure. The port monitor is on the way to becoming stopped.
Notrunning
Inactive state – The port monitor has been killed. All ports previously monitored are inaccessible. An external user cannot tell whether a port is disabled or notrunning.
Failed
Inactive state – The port monitor is unable to start and remain running.
To determine the state of any particular port monitor, use the following command:
# sacadm -l -p portmon-name
