System Administration Guide: Advanced Administration
ProcedureHow to Change Scheduling Parameters of a Timesharing Process (priocntl)
  1. Become superuser or assume an equivalent role.
    Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
  2. Change the scheduling parameters of a running timesharing process.
    # priocntl -s -m user-limit [-p user-priority] -i idtype idlist
    -s
    Lets you set the upper limit on the user priority range and change the current priority.
    -m user-limit
    When you use the -p option, specifies the maximum amount you can raise or lower the priority.
    -p user-priority
    Allows you to designate a priority.
    -i xidtype xidlist
    Uses a combination of xidtype and xidlist to identify the process or processes. The xidtype specifies the type of ID, such as the process ID or the user ID. Use xidlist to identify a list of process IDs or user IDs.
  3. Verify the process status.
    # ps -ecl | grep idlist
Example 12–8 Changing Scheduling Parameters of a Timesharing Process (priocntl)
The following example shows how to execute a command with a 500-millisecond time slice, a priority of 20 in the RT class, and a global priority of 120.
# priocntl -e -c RT -m 500 -p 20 myprog
# ps -ecl | grep myprog
