System Administration Guide: Advanced Administration
Daily Command Summary
The Daily Command Summary report shows the system resource utilization by command. With this report, you can identify the most heavily used commands. Based on how those commands use system resources, you can then gain insight on how best to tune the system.
These reports are sorted by TOTAL KCOREMIN, which is an arbitrary gauge but often useful for calculating drain on a system.
A sample Daily Command Summary follows:
								TOTAL COMMAND SUMMARY
COMMAND   NUMBER      TOTAL   TOTAL     TOTAL   MEAN    MEAN     HOG   CHARS   BLOCKS
NAME        CMDS    KCOREMIN CPU-MIN REAL-MIN  SIZE-K  CPU-MIN  FACTOR TRNSFD  READ
TOTALS      2150  1334999.75  219.59 724258.50 6079.48   0.10   0.00   397338982 419448
netscape      43  2456898.50   92.03  54503.12 26695.51  2.14   0.00   947774912 225568
adeptedi       7    88328.22    4.03    404.12 21914.95  0.58   0.01    93155160   8774
dtmail         1    54919.17    5.33  17716.57 10308.94  5.33   0.00   213843968  40192
acroread       8    31218.02    2.67  17744.57 11682.66  0.33   0.00   331454464  11260
dtwm           1    16252.93    2.53  17716.57 6416.05   2.53   0.00   158662656  12848
dtterm         5     4762.71    1.30  76300.29 3658.93   0.26   0.00    33828352  11604
dtaction      23     1389.72    0.33      0.60 4196.43   0.01   0.55    18653184    539
dtsessio       1     1174.87    0.24  17716.57 4932.97   0.24   0.00    23535616   5421
dtcm           1      866.30    0.18  17716.57 4826.21   0.18   0.00     3012096   6490
The following list describes the data provided by the Daily Command Summary.
COMMAND NAME
Name of the command. All shell procedures are lumped together under the name sh because only object modules are reported by the process accounting system. You should monitor the frequency of programs called a.out or core, or any other unexpected name. You can use the acctcom program to determine who executed an oddly named command and if superuser privileges were used.
NUMBER CMDS
Total number of times this command was run.
TOTAL KCOREMIN
Total cumulative measurement of the Kbyte segments of memory used by a process per minute of run time.
TOTAL CPU-MIN
Total processing time this program accumulated.
TOTAL REAL-MIN
Total real-time (wall-clock) minutes this program accumulated.
MEAN SIZE-K
Mean (average) of the TOTAL KCOREMIN over the number of invocations reflected by the NUMBER CMDS.
MEAN CPU-MIN
Mean (average) derived from the NUMBER CMDS and the TOTAL CPU-MIN.
HOG FACTOR
Total CPU time divided by elapsed time. Shows the ratio of system availability to system utilization, providing a relative measure of total available CPU time consumed by the process during its execution.
CHARS TRNSFD
Total number of characters transferred by the read and write system calls. Might be negative due to overflow.
BLOCKS READ
Total number of the physical block reads and writes that a process performed.
