System Administration Guide: Advanced Administration
Scheduling a Repetitive System Task (cron)
The following sections describe how to create, edit, display, and remove crontab files, as well as how to control access to them.
Inside a crontab File
The cron daemon schedules system tasks according to commands found within each crontab file. A crontab file consists of commands, one command per line, that will be executed at regular intervals. The beginning of each line contains date and time information that tells the cron daemon when to execute the command.
For example, a crontab file named root is supplied during SunOS software installation. The file's contents include these command lines:
10 3 * * * /usr/sbin/logadm (1)
15 3 * * 0 /usr/lib/fs/nfs/nfsfind (2)
1 2 * * * [ -x /usr/sbin/rtc ] && /usr/sbin/rtc -c > /dev/null 2>&1 (3)
30 3 * * * [ -x /usr/lib/gss/gsscred_clean ] && /usr/lib/gss/gsscred_clean (4)
The following describes the output for each of these command lines:
For more information about the syntax of lines within a crontab file, see Syntax of crontab File Entries.
The crontab files are stored in the /var/spool/cron/crontabs directory. Several crontab files besides root are provided during SunOS software installation. See the following table.
Table 8–2 Default crontab Files
crontab File
General system functions and file system cleanup
Performance data collection
General uucp cleanup
Besides the default crontab files, users can create crontab files to schedule their own system tasks. Other crontab files are named after the user accounts in which they are created, such as bob, mary, smith, or jones.
To access crontab files that belong to root or other users, superuser privileges are required.
Procedures explaining how to create, edit, display, and remove crontab files are described in subsequent sections.
How the cron Daemon Handles Scheduling
The cron daemon manages the automatic scheduling of crontab commands. The role of the cron daemon is to check the /var/spool/cron/crontab directory for the presence of crontab files.
The cron daemon performs the following tasks at startup:
In much the same way, the cron daemon controls the scheduling of at files. These files are stored in the /var/spool/cron/atjobs directory. The cron daemon also listens for notifications from the crontab commands regarding submitted at jobs.
A crontab file consists of commands, one command per line, that execute automatically at the time specified by the first five fields of each command line. These five fields, described in the following table, are separated by spaces.
Table 8–3 Acceptable Values for crontab Time Fields
Time Field
Day of month
Day of week
0-6 (0 = Sunday)
Follow these guidelines for using special characters in crontab time fields:
For example, the following crontab command entry displays a reminder in the user's console window at 4 p.m. on the first and fifteenth days of every month.
0 16 1,15 * * echo Timesheets Due > /dev/console
Each command within a crontab file must consist of one line, even if that line is very long. The crontab file does not recognize extra carriage returns. For more detailed information about crontab entries and command options, refer to the crontab(1) man page.
