This table summarizes the commands available for displaying information about file size and disk space.
Command |
Description |
Man Page |
df |
Reports the number of free disk blocks and files | |
du |
Summarizes disk space allocated to each subdirectory | |
find -size |
Searches recursively through a directory based on the size specified with the -size option | |
ls -lh |
Lists the size of a file in the power of 1024 scaling |
Display information about how disk space is used by using the df command.
$ df [directory] [-h] [-t] |
With no options, lists all mounted file systems and their device names, the number of 512-byte blocks used, and the number of files.
Specifies the directory whose file system you want to check.
Displays disk space in the power of 1024 scaling.
Displays the total blocks as well as the blocks used for all mounted file systems.
In the following example, all the file systems listed are locally mounted except for /usr/dist.
$ df / (/dev/dsk/c0t0d0s0 ): 101294 blocks 105480 files /devices (/devices ): 0 blocks 0 files /system/contract (ctfs ): 0 blocks 2147483578 files /proc (proc ): 0 blocks 1871 files /etc/mnttab (mnttab ): 0 blocks 0 files /etc/svc/volatile (swap ): 992704 blocks 16964 files /system/object (objfs ): 0 blocks 2147483530 files /usr (/dev/dsk/c0t0d0s6 ): 503774 blocks 299189 files /dev/fd (fd ): 0 blocks 0 files /var/run (swap ): 992704 blocks 16964 files /tmp (swap ): 992704 blocks 16964 files /opt (/dev/dsk/c0t0d0s5 ): 23914 blocks 6947 files /export/home (/dev/dsk/c0t0d0s7 ): 16810 blocks 7160 files |
In the following example, file system information for a system with a UFS root file system is displayed in 1024 bytes.
$ df -h Filesystem size used avail capacity Mounted on /dev/dsk/c0t0d0s0 249M 200M 25M 90% / /devices 0K 0K 0K 0% /devices ctfs 0K 0K 0K 0% /system/contract proc 0K 0K 0K 0% /proc mnttab 0K 0K 0K 0% /etc/mnttab swap 485M 376K 485M 1% /etc/svc/volatile objfs 0K 0K 0K 0% /system/object /dev/dsk/c0t0d0s6 3.2G 2.9G 214M 94% /usr fd 0K 0K 0K 0% /dev/fd swap 485M 40K 485M 1% /var/run swap 485M 40K 485M 1% /tmp /dev/dsk/c0t0d0s5 13M 1.7M 10M 15% /opt /dev/dsk/c0t0d0s7 9.2M 1.0M 7.3M 13% /export/home |
Although /proc and /tmp are local file systems, they are not UFS file systems. /proc is a PROCFS file system, /var/run and /tmp are TMPFS file systems, and /etc/mnttab is an MNTFS file system.
In the following example, file system information for a system with a Oracle Solaris ZFS root file system is displayed in 1024 bytes.
Filesystem size used avail capacity Mounted on rpool/ROOT/s1008be 67G 4.6G 58G 8% / /devices 0K 0K 0K 0% /devices ctfs 0K 0K 0K 0% /system/contract proc 0K 0K 0K 0% /proc mnttab 0K 0K 0K 0% /etc/mnttab swap 1.9G 1.5M 1.9G 1% /etc/svc/volatile objfs 0K 0K 0K 0% /system/object sharefs 0K 0K 0K 0% /etc/dfs/sharetab /platform/sun4u-us3/lib/libc_psr/libc_psr_hwcap1.so.1 63G 4.6G 58G 8% /platform/sun4u-us3/lib/libc_psr.so.1 /platform/sun4u-us3/lib/sparcv9/libc_psr/libc_psr_hwcap1.so.1 63G 4.6G 58G 8% /platform/sun4u-us3/lib/sparcv9/libc_psr.so.1 fd 0K 0K 0K 0% /dev/fd rpool/ROOT/s1008be/var 67G 73M 58G 1% /var swap 1.9G 32K 1.9G 1% /tmp swap 1.9G 40K 1.9G 1% /var/run rpool/export 67G 20K 58G 1% /export rpool/export/home 67G 18K 58G 1% /export/home |
The following example shows a list of all mounted file systems, device names, total 512-byte blocks used, and the number of files. The second line of each two-line entry displays the total number of blocks and files that are allocated for the file system.
$ df -t / (/dev/dsk/c0t0d0s0 ): 101294 blocks 105480 files total: 509932 blocks 129024 files /devices (/devices ): 0 blocks 0 files total: 0 blocks 113 files /system/contract (ctfs ): 0 blocks 2147483578 files total: 0 blocks 69 files /proc (proc ): 0 blocks 1871 files total: 0 blocks 1916 files /etc/mnttab (mnttab ): 0 blocks 0 files total: 0 blocks 1 files /etc/svc/volatile (swap ): 992608 blocks 16964 files total: 993360 blocks 17025 files /system/object (objfs ): 0 blocks 2147483530 files total: 0 blocks 117 files /usr (/dev/dsk/c0t0d0s6 ): 503774 blocks 299189 files total: 6650604 blocks 420480 files /dev/fd (fd ): 0 blocks 0 files total: 0 blocks 31 files /var/run (swap ): 992608 blocks 16964 files total: 992688 blocks 17025 files /tmp (swap ): 992608 blocks 16964 files total: 992688 blocks 17025 files /opt (/dev/dsk/c0t0d0s5 ): 23914 blocks 6947 files total: 27404 blocks 7168 files /export/home (/dev/dsk/c0t0d0s7 ): 16810 blocks 7160 files total: 18900 blocks 7168 files |
