System Administration Guide: Advanced Administration
ProcedureHow to Display the User Ownership of Local UFS File Systems
  1. Become superuser or assume an equivalent role.
    Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
  2. Display users, directories, or file systems, and the number of 1024-byte blocks used.
    # quot [-a] [filesystem ...]
    -a
    Lists all users of each mounted UFS file system and the number of 1024-byte blocks used.
    filesystem
    Identifies a UFS file system. Users and the number of blocks used are displayed for that file system.
    Note –
    The quot command works only on local UFS file systems.
Example 6–10 Displaying the User Ownership of Local UFS File Systems
In the following example, users of the root (/) file system are displayed. In the subsequent example, users of all mounted UFS file systems are displayed.
# quot /
/dev/rdsk/c0t0d0s0:
43340   root
 3142   rimmer
   47   uucp
   35   lp
   30   adm
    4   bin
    4   daemon
# quot -a
/dev/rdsk/c0t0d0s0 (/):
43340   root
 3150   rimmer
   47   uucp
   35   lp
   30   adm
    4   bin
    4   daemon
/dev/rdsk/c0t0d0s6 (/usr):
460651  root
206632  bin
  791   uucp
   46   lp
    4   daemon
    1   adm
/dev/rdsk/c0t0d0s7 (/export/home):
    9   root
