Become superuser or assume an equivalent role.
Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
Use the quota editor to create a temporary file that contains one line of quota information for each mounted UFS file system that has a quotas file in the file system's root directory.
# edquota username |
where username is the user for whom you want to set up quotas.
Change the number of 1-Kbyte disk blocks, both soft and hard, to the quotas that you specify for each file system.
Change the number of inodes, both soft and hard, from the default of 0, to the quotas that you specify for each file system.
Verify the user's UFS quota.
# quota -v username |
Displays the user's quota information on all mounted file systems where quotas exist.
Specifies the user name to view quota limits.
The following example shows the contents of the temporary file opened by edquota on a system where /files is the only mounted file system that contains a quotas file in the root directory.
fs /files blocks (soft = 0, hard = 0) inodes (soft = 0, hard = 0) |
The following example shows the same line in the temporary file after quotas have been set up.
fs /files blocks (soft = 50, hard = 60) inodes (soft = 90, hard = 100) |
