System Administration Guide: Advanced Administration
Checking UFS Quotas
After you have set up and turned on UFS disk quotas and inode quotas, you can check for users who exceed their quotas. In addition, you can check quota information for entire file systems.
The following table describes the commands that you use to check quotas.
Table 7–2 Commands for Checking UFS Quotas
Command
Task
quota(1M)
Displays user quotas and current disk use, and information about users who are exceeding their quotas
repquota(1M)
Displays quotas, files, and the amount of space that is owned for specified file systems
ProcedureHow to Check for Exceeded UFS Quotas
You can display the UFS quotas and disk use for individual users on file systems on which quotas have been activated by using the quota command.
  1. Become superuser or assume an equivalent role.
    Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
  2. Display user quotas for mounted file systems where quotas are enabled.
    # quota [-v] username
    -v
    Displays one or more users' quotas on all mounted file systems that have quotas.
    username
    Is the login name or UID of a user's account.
Example 7–6 Checking for Exceeded UFS Quotas
The following example shows that the user account identified by UID 301 has one 1–Kbyte quota but has not used any disk space.
# quota -v 301
Disk quotas for bob (uid 301):
Filesystem  usage  quota limit timeleft files quota  limit timeleft
/export/home   0      1     2             0      2      3
Filesystem
Is the mount point for the file system.
usage
Is the current block usage.
quota
Is the soft-block limit.
limit
Is the hard-block limit.
timeleft
Is the amount of time, in days, left on the quota timer.
files
Is the current inode usage.
quota
Is the soft-inode limit.
limit
Is the hard-inode limit.
timeleft
ProcedureHow to Check UFS Quotas on a File System
Display the UFS quotas and disk use for all users on one or more file systems by using the repquota command.
  2. Display all UFS quotas for one or more file systems, even if there is no usage.
    # repquota [-v]  -a filesystem
    -v
    Reports on UFS quotas for all users, even those users who do not consume resources.
    -a
    Reports on all file systems.
    filesystem
    Reports on the specified file system.
Example 7–7 Checking UFS Quotas on a File System
The following example shows output from the repquota command on a system that has quotas enabled on only one file system (/export/home).
# repquota -va
/dev/dsk/c0t3d0s7 (/export/home):
                  Block limits              File limits
User      used   soft   hard  timeleft  used  soft   hard  timeleft
#301  --            0      1   2.0 days         0      2      3
#341  --    57     50     60   7.0 days  2      90    100
Block limits
Definition
used
soft
hard
timeleft
File limits
Is the definition of the file limits.
used
soft
hard
timeleft
