System Administration Guide: Advanced Administration
Expanded Core File Names
If a global core file directory is enabled, core files can be distinguished from one another by using the variables described in the following table.
Variable Name
Variable Definition
Executable file directory name, up to a maximum of MAXPATHLEN characters
Executable file name, up to a maximum of MAXCOMLEN characters
Effective group ID
Machine name (uname -m)
System node name (uname -n)
Process ID
Decimal value of time(2)
Effective user ID
Name of the zone in which process is executed (zonename)
Literal %
For example, if the global core file path is set to:
and a sendmail process with PID 12345 terminates abnormally, it produces the following core file:
