System Administration Guide: Advanced Administration
How to Display the Current Core Dump Configuration
Use the coreadm command without any options to display the current core dump configuration.
$ coreadm
               global core file pattern:
     global core file content: default
       init core file pattern: core
       init core file content: default
            global core dumps: disabled
       per-process core dumps: enabled
      global setid core dumps: disabled
 per-process setid core dumps: disabled
     global core dump logging: disabled
