System Administration Guide: Advanced Administration
ProcedureHow to Disable or Enable Saving Crash Dumps
  1. Become superuser or assume an equivalent role.
    Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
  2. Disable or enable the saving of crash dumps on your system.
    # dumpadm -n | -y
Example 17–3 Disabling the Saving of Crash Dumps
This example illustrates how to disable the saving of crash dumps on your system.
# dumpadm -n
      Dump content: all pages
       Dump device: /dev/dsk/c0t1d0s1 (dedicated)
Savecore directory: /var/crash/pluto (minfree = 77071KB)
  Savecore enabled: no
   Save Compressed: on
Example 17–4 Enabling the Saving of Crash Dumps
This example illustrates how to enable the saving of crash dump on your system.
# dumpadm -y
  Savecore enabled: yes
   Save compressed: on
