System Administration Guide: Advanced Administration
ProcedureHow to Diagnose and Correct Search Path Problems
  1. Display the current search path to verify that the directory for the command is not in your path or that it isn't misspelled.
    $ echo $PATH
  2. Check the following:
    • Is the search path correct?
    • Is the search path listed before other search paths where another version of the command is found?
    • Is the command in one of the search paths?
    If the path needs correction, go to step 3. Otherwise, go to step 4.
  3. Add the path to the appropriate file, as shown in this table.
    Shell
    File
    Syntax
    Notes
    Bourne and Korn
    $HOME/.profile
    $ PATH=$HOME/bin:/sbin:/usr/local /bin ...
    $ export PATH
    A colon separates path names.
    $HOME/.cshrc
    or
    $HOME/.login
    hostname% set path=(~bin /sbin /usr/local/bin ...)
    A blank space separates path names.
  4. Activate the new path as follows:
    Shell
    File Where Path Is Located
    Use this Command to Activate The Path
    Bourne and Korn
    .profile
    $ . ./.profile
    .cshrc
    hostname% source .cshrc
    .login
    hostname% source .login
  5. Verify the new path.
    $ which command
Example 19–1 Diagnosing and Correcting Search Path Problems
This example shows that the mytool executable is not in any of the directories in the search path using the which command.
venus% mytool
mytool: Command not found
venus% which mytool
no mytool in /sbin /usr/sbin /usr/bin /etc /home/ignatz/bin  .
venus% echo $PATH
venus% vi ~/.cshrc
(Add appropriate command directory to the search path)
venus% source .cshrc
venus% mytool
If you cannot find a command, look at the man page for its directory path. For example, if you cannot find the lpsched command (the lp printer daemon), the lpsched(1M) man page tells you the path is /usr/lib/lp/lpsched.
